saw a thread for e-brake fix.. which fix would be needed for this
Old May 9, 2006 | 12:44 AM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
Default saw a thread for e-brake fix.. which fix would be needed for this
The ebrake barely works.. it makes the car roll still with it up. The problem that I see is that the ebrake goes all the way up.. it doesn't stop I can pull it much farter up then I should be able 2..
Which fix would be needed for this problem
Old May 9, 2006 | 08:00 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Cable splits to two with an equalizer. One side could be off or the shoes could be worn out. Pull the rear wheels and see if the cables on both side are working. If so check the shoe by removing the rear drums. Disengage brake while removing them. Do you feel any tension when you pull it up or is the cable broken?
Old May 9, 2006 | 09:45 AM
glennxx1's Avatar
glennxx1
i have the same problem except....mine doesnt work at all, the cable does get tighter though, but i can move the car with the E brake engaged, gets anoyin, when i get out to open my garage i have to cut the car off and leave it in gear so it wont roll
Old May 9, 2006 | 10:12 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
Unfortunately you will probably need to remove the calipers and rotors(rear), and adjust the drum shoe brake inside the rotor. It's not a simple job for a non mechanical person, take it to a professional!
To saw a thread for e-brake fix.. which fix would be needed for this
