Hearing a whining noise.?.
Old May 9, 2006 | 08:31 AM
gotnovette's Avatar
gotnovette
Default Hearing a whining noise.?.
Hey guys!
I just started hearing a whining noise from under the hood. I have a 2000 vert with no mods under the hood and 30K on the clock. Its not there all the time, not too loud either. It seemed to quiet down a bit when I turned the wheel, then came back when I straightened out.
I thought it might be a loose belt, but its not that high pitched screech that you get from a belt. Could it be a pump going bad?
Any suggestions before I bring it in and get ripped off for ignorance would certainly be appreciated!
Old May 9, 2006 | 10:13 AM
Stiffy's Avatar
Stiffy
Im sure you did check but .....have you check power sterring fluids?
Old May 9, 2006 | 12:48 PM
gotnovette's Avatar
gotnovette
Yup, checked that. Anything else I can look for?
Old May 9, 2006 | 04:52 PM
DngrZne's Avatar
DngrZne
I would think that if it responds to changes in the angle of the wheel maybe it's the steering pump starting to go.
Old May 10, 2006 | 02:15 AM
THE BLACK WIDOW's Avatar
THE BLACK WIDOW
My oil filler cap seal went bad and it sounded like a high pitched vaccuum leak. Drove me crazy forever trying to pinpoint it until one day I pulled the cap with the car running and figured it out. Not sure if thats the sound you are hearing but thought I'd chime in.
J
Old May 10, 2006 | 05:59 PM
gotnovette's Avatar
gotnovette
J
I appreciate the tip, I'll check it out!
To Hearing a whining noise.?.
