c4c5specialist, could I have your custom alignment specs?
c4c5specialist,
Several other Forum members have raved about the custom alignment specs that you use and I would like to use those same specs. I am running the Firestone Runflats so I'm not sure that I should go for the full Z06 specs on these tires after I lower my car. If you could post or e-mail me the complete specs that you use I'd REALLY appreciate it! Thanks!!!
From: Time flies like an arrow...fruit flies like a banana
Cruise-In I Veteran
Re: c4c5specialist, could I have your custom alignment specs? (Tormania)
I'm just about to get mine aligned and have switched to non-runflats, so if I could get it to I'd be much obliged! Jdemoor@mediaone.net Thanks in advance ! :cheers: :cheers:
I know c4c5 does a lot of stuff based on a single person's need :D....so the specs he supplied me may not be extacly what you want but these are between stock and Z06 leaning towards performance. Again, these were given to me by THE MAN
about the variation, c4c5 told me that if the actual is as close as possible to the individual specs listed, then you'll automatically be within the "cross difference variation"....made sense to me....each of my individual specs are almost dead on, so no need to worry about the variation
