Adequate Warm Up Temp.
Old Aug 23, 2001 | 02:54 PM
rosecustom's Avatar
rosecustom
Default Adequate Warm Up Temp.
I am interested in knowing what operating temperature is considered safe before mildly mashing the accelerator pedal to ... say... 4000 rpm between shifts on my 2000. I always tried to have my vehicles properly warmed up but I'm not sure about the LS1.
Old Aug 23, 2001 | 03:01 PM
chuckoc's Avatar
chuckoc
Default Re: Adequate Warm Up Temp. (rosecustom)
While I am NOT a TECH, I consider common sense as a good guide, I feel that being the LS1 is all Alum. not only temps should be of a certain level I feel that getting everything equal or "heat synced" is my rule of thumb, so I get the car up to normal op. temp (174 in my case) and I like to see my oil with-in 10 degrees of that and that way I know all the alum. is all about the same temp and I feel like I won't blow any gaskets etc.. I would at the VERY least make sure your thermostat is OPEN before laying her open, otherwise I think there is undue stress on water pump and other parts of system. It only takes about 10-15 min (outside temp over 65) to get the car to those temps.
Old Aug 23, 2001 | 03:37 PM
MitchAlsup's Avatar
MitchAlsup
Look at the oil temp, not the water temp. When the oil gets to 150 the engine is fully warmed up. This is generally twice as long as it takes the water to get to temp.
By this point, the block and heads will have achieved operating temps, and the oil will be protecting and cooling the engine.
Old Aug 23, 2001 | 05:57 PM
SilverStar's Avatar
SilverStar
Default Re: Adequate Warm Up Temp. (MitchAlsup)
I have always read here on the forum that oil temp of 130 or greater = WOT. :D [IMG][/IMG]
Old Aug 23, 2001 | 06:38 PM
TestAmenTC5's Avatar
TestAmenTC5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
I won't take it to redline until the oil is at least 185. Taking it to 4000 I would probably do it around 165-170.
Old Aug 23, 2001 | 10:39 PM
Avanti's Avatar
Avanti
Default Re: Adequate Warm Up Temp. (TestAmenTC5)
I presume you know what your usual warmed-up and running temps are. Why not simply wait until they show? Unless it's pretty cold it doesn't take long-- atleast not here in the South. Good luck.
To Adequate Warm Up Temp.
