Brake Caliper Removal
Old May 10, 2006 | 09:16 PM
dcking04vette's Avatar
dcking04vette
Default Brake Caliper Removal
I'm trying to remove the rear brake calipers to install some Baer rotors and brakes. The top bolts that hold the caliper came off easily. However, the 21mm bolts that hold the pads, can't budge.
Suggetions? I've just sprayed some wd-40, waiting on to soak in.
I don't want to put too much weight on the spindle, because it's flexing.
Old May 10, 2006 | 10:29 PM
Tigershark3's Avatar
Tigershark3
Bump for you.
Old May 10, 2006 | 10:45 PM
rws.1's Avatar
rws.1
The large bracket bolts are torqued to 125 ft-lbs and have red locktite on them... you need a breaker bar or a strong impact gun to break them loose.
The caliper bolts have blue locktite and should only be torqued to 23 ft-lbs... they should be snap.
Old May 11, 2006 | 07:25 AM
TPR492's Avatar
TPR492
St. Jude Donor '06
Old May 11, 2006 | 08:01 AM
dcking04vette
Thanks for the bump and all the info.
Managed to get one of the top 21mm bolts off, still working on the bottom. I thought that my air compressior would handle, but doesn't seem to have enough juice. It's 125 psi. What do you need to be able to use?
Old May 11, 2006 | 08:20 AM
yellow01's Avatar
yellow01
If you have a torch, gently heat the spindle where the 21mm goes in. This will help release the loctite.
Old May 11, 2006 | 02:02 PM
UstaB-GS549's Avatar
UstaB-GS549
1/2" drive breaker bar and big rubber mallet got mine loose.
Old May 11, 2006 | 02:07 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
it's the red loctite that is the problem... 125 ft lbs is not that difficult to achieve....the stuff turns to cement.. it need to be really bullied, or shocked to break it lose.. a non loctited bolt torqued to 125 is not that difficult..
Old May 11, 2006 | 02:39 PM
yellow01's Avatar
yellow01
I forgot to add that for mine, a barrage of f-words and a few m-fers intimidated the bolts to come loose
Old May 11, 2006 | 03:17 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
3 foot breaker bar, wether impact or bb, be sure to use a 6pt socket
Old May 11, 2006 | 03:20 PM
MattB's Avatar
MattB
I had one of the 21mm on the rear that would not budge. I got a 36inch long 3/4 black pipe to put over my breaker bar and then jumped up and down on it until it turned Serriously, I'm 190lbs an it took all my body weight on the end of that pipe to break the bolt loose.
Good luck, and be careful not to put your Vette on the ground trying to remove that bolt
Old May 11, 2006 | 04:08 PM
Milkman2's Avatar
Milkman2
St. Jude Donor '06-'07
This red loctite stuff sounds like fun to work with .. Is it needed for the assemble process??
Old May 11, 2006 | 04:34 PM
1FUNVTT's Avatar
1FUNVTT
- This worked for me on similar situations... Doesn't take too much heat and use a long breaker bar. I have heard some people place a small jack under the bar and carefully uses the jack to break the hold. However, if you do that, watch to see if the bar doesn't bend or if it is lifting the car up... Good Luck
Old May 11, 2006 | 08:46 PM
RED99's Avatar
RED99
You are suppose to use new bolts for the calipers and the caliper brackets that has the loctite already made on it.
Old May 11, 2006 | 10:59 PM
dcking04vette
Can't I use the old bolts w/new red locktite?
Old May 12, 2006 | 10:50 AM
yellow01's Avatar
yellow01
Many many people have, myself included. If you do this frequently, I'd replace every so often due to the high torque and bolt stretching, but many people in RR remove them frequently and don't always replace.
Old May 12, 2006 | 12:28 PM
tiojames's Avatar
tiojames
Default brake bolts
Just went thru the process myself. I got a box end wrench on the bolt head and took a 5 lb. hand sledge, held tension against the wrench and whacked it with the hammer. They came right off. I tried my impact first and it couldn't do the job. The hammer worked easily on all four brakes. After the first whack the air gun did the rest.
To Brake Caliper Removal
Old May 12, 2006 | 02:01 PM
NoOne's Avatar
NoOne
Go buy a Harbor Freight Earthquake 600ft lb impact.
Its cheap stuff, $79, but mine has never failed me and I oil it after every use.
It will make easy work of those bolts and take them right off.
I just did this 2 days ago.
If your trying to use a air ratchet it won't budge those.
I've tried the jack under the wrench part too, not on the C5 but on my wife's Miata. I lifted the entire car off of the jackstands about and it didn't move, this was before the air compressor and impact
Old May 12, 2006 | 04:35 PM
2kbluestreak's Avatar
2kbluestreak
Count to 60 seconds for the propane torch on each boss that the 21mm bolts torque into. Wire brush to clean the threads on the orignal bolts and apply red Loctite when you re-install. A mechanic with a lift has it much easier in the rear because he can have the handle of the breaker bar down. Can't do this in your garage because of the floor and can't get a decent size breaker bar inside the wheel wells. Front brakes are a lot easier for the same bolts because you can turn the wheels so that the end of the breaker bar is outside the fender.
Old May 12, 2006 | 06:32 PM
r2d2nate's Avatar
r2d2nate
A breaker bar -- with a length of black pipe (home depot) over it to lengthen and increase your torque. Cheap and it works. I use a 30" long, 1 1/2" black pipe.
