squeaking belt
Old May 11, 2006 | 09:59 AM
Silvervettes's Avatar
Silvervettes
St. Jude Donor '07
Default squeaking belt
The belt that drives the water pump squeaks loudly on my 97 vette. Will putting a new belt on solve the problem? I just replaced the A/C belt.
Old May 11, 2006 | 11:49 AM
ImaRoadDog's Avatar
ImaRoadDog
If you are going to go with new belts then get the Goodyear Gatorback belts. I replaced my belts with the GM ones and the squeak came back after awhile. Now I just silicone the belts every now and then and the squeak goes away for awhile. Might try that too to ensure the squeak you have is a belt and not a pully or other device making the noise.
Old May 11, 2006 | 01:41 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You have two belt systems on your car. One is the drive belt system, the other is the air conditioner belt system.
The drive belt system consists of the serpentine belt,the power steering pump, alternator/gen, water pump, harmonic balancer, idler pulley,belt auto tensioner pulley.
The AC belt system consists of the compressor, harmonic balancer,idler pulley, belt auto tensioner pulley.
First thing you need to do is isolate which system is squeaking. this can be done by releasing tension on the drive belt tensioner and removing the serp belt. This is the outboard belt of the two belt systems..if the squeak goes away, then it is the belt or a component of the drive system.
If the squeak is still there, then it is a component of the ac belt system.
to verify this release the belt tension from the tensioner and remove the belt. if the squeak goes away, then it is a component of the ac belt system..
A common problem is the belt tensioner on either system.. but verifying which system is at fault is the proper procedure.
You could replace both belts, but you may still have the squeak. So if you want to find the culprit, isolate the system, then spray the belt of the offending system and see if the squeak goes away. Try to stay away from the idler and tensioner while spaying..
I find that belt dressing may be good to identify a belt problem, but it is a temporary fix at best..
The real problem has been the tensioner and the idler.. both of these components have a sealed bearing which has been know to dry up or redirect the grease away from the bearing, thus causing the squeak.
If you find that a belt change does not correct the problem, then a change of both the idler and tensioner pulley is in order. If you just change the idler or the tensioner alone, it will cause the other component to go bad in a month or so. This has been the case with many members..There was a change made to the dusts seals to help correct this problem in newer C5's.
Lots of tensioner and idler pulleys have been identified as a problem.. and it can effect either system. One is not more prevalent than the other. So find out which system is squeaking first, in the drive belt system, it could also be the bearing of the alternator, power steering pump, or water pump too, but these are less probable.
I hope this makes things alittle clearer
ET
Old Jun 2, 2006 | 06:10 PM
b.j.prescott's Avatar
b.j.prescott
I dont believe id crank that car without a belt if i were you.In real world you can very easily blow the diodes in yr alt....better think that one over again!!!!!!
Old Jun 2, 2006 | 06:49 PM
Evil-Twin's Avatar
Evil-Twin
I notice you give nothing but really bad information here...
The latest round of No it alls are infiltrating this forum......people with little or no automotive knowledge.
Old Jun 2, 2006 | 07:34 PM
fireinskyc5's Avatar
fireinskyc5
To squeaking belt
