Head and Cam advise needed...
Old May 12, 2006 | 10:08 AM
sting66cp's Avatar
sting66cp
Default Head and Cam advise needed...
I am looking to do the first serious mod to my 01 LS1. I want to do a head and cam package. I am looking for a lot of low to mid range power and torque and want to maintain a nice idle with good driveability. I was thinking of an LS6 head and cam package, or maybe a little more cam than the stock LS6. Is there a reason to upgrade to higher flowing heads like the AFR's if I'm not going with an agressive cam?
Old May 12, 2006 | 12:54 PM
AJay's Avatar
AJay
I'm doing a H/C package on my car next month. I decided to go with AFR Heads over LS6 primarily because the AFR's have smaller ports with higher velocities. My reasoning is that the 205 cc heads will perform better in the low and mid range RPM range then the larger ported LS6 Heads. As for the cam, I'm going with a conservative "old man" grind but definately more duration and lift then the stock LS6. If you do a search, you will find enough material on cams to keep you reading for a month Good luck and keep us posted on your results
Old May 12, 2006 | 01:15 PM
Laguna Blu's Avatar
Laguna Blu
As we all know moding our vettes is a disease with no known cure. I would go with the best possible flowing heads, just in case you continue modding later. Of course several years down the line there will be better performing products available as well.
Old May 12, 2006 | 01:40 PM
402Sam's Avatar
402Sam
I would do a really go set of heads and a good cam just in case later on you dont have to do it again..
Old May 12, 2006 | 01:57 PM
mdhmi's Avatar
mdhmi
AFR 205 heads milled .030 with a 224 cam.
Mark
Old May 12, 2006 | 07:15 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
AFR 205s milled .020, 224/228@114 cam
This setup kicks ***!
To Head and Cam advise needed...
