Surge Tank Cap PSI
Old May 13, 2006 | 05:37 PM
VERTC5's Avatar
VERTC5
Default Surge Tank Cap PSI
I got a new cap from dealer and it doesn't seem to fit the same as the original. It also has "Engine Coolant 18 PSI Presure on it" while the original has "15 PSI" on it.
The part number GM# 25713160 appears correct. Did they change the pressure or maybe is the wrong cap in the box?
Old May 13, 2006 | 06:35 PM
LoneStarFRC's Avatar
LoneStarFRC
From what I've seen myself, the 18 pounder is the new replacement version for the 15.
I'm curious about what you mean when you say "it doesn't seem to fit the same as the original". It should just screw on like the old one with no problems.
Old May 13, 2006 | 06:39 PM
VERTC5's Avatar
VERTC5
It doesn't seem to go down as far as the original. Maybe it's going down far enough to seal. I guess I'll try it and see if it is under pressure after running the car.
Old May 13, 2006 | 06:45 PM
LoneStarFRC
I replaced mine a few months ago and it's working fine since. Seems like I remember looking the new one over pretty closely and noticed it is manufactured by a different vendor for GM than the original.
Old May 14, 2006 | 08:07 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Just replaced mine last week. The new one looks slightly different and is about 1/8" taller but screws down the same. BTW, the new one is made in China!
Old May 14, 2006 | 09:29 PM
VERTC5's Avatar
VERTC5
The box said made in India for mine.
Old May 15, 2006 | 04:15 PM
Dirty Howie's Avatar
Dirty Howie
Why are all you guys having to switch out your caps ????????
DH
Old May 15, 2006 | 07:59 PM
davekp78's Avatar
davekp78
DH
The original one quit working!
Seriously, one day I noticed the lower radiator hose was collapsed. The old cap wasn't allowing air in. Also, I was wrong - my new cap was from India, not China.
Old May 16, 2006 | 12:53 PM
TEXHAWK0's Avatar
TEXHAWK0
Does the taller cap cause a clearance problem with the hood?
I still wonder why they went to 18 psi instead of 15.
Old May 16, 2006 | 05:31 PM
davekp78's Avatar
davekp78
No clearance problem- I don't see any compressing of the hood insulation over the cap area. Don't know why the increase in pressure- it raises the boiling point of water up about 5 degrees.
To Surge Tank Cap PSI
