Oil Temp...
Old May 13, 2006 | 10:24 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Oil Temp...
What are you guys seeing on a warm day (80+) and playing a bit?
Old May 13, 2006 | 10:39 PM
ArKay99's Avatar
ArKay99
200 to 205F. I have a 160* thermostat.
Old May 13, 2006 | 10:42 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
in the low 2's....
Old May 13, 2006 | 11:22 PM
Bounty's Avatar
Bounty
Here in South Florida (95+) with the stock cooling setup I would regularly see 220 - 225 oil temps. After cleaning radiator of dirt/debris, flushing coolant, and adding a bottle of Redline Water Wetter the oil temps never go over 205 - 210.
Old May 14, 2006 | 12:28 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Thanks guys, I have seen 210-220 and I am seriously thinking of investing in an oil cooler setup.
Anyone ever run one of these?
Old May 14, 2006 | 12:42 AM
triblk6spd's Avatar
triblk6spd
that is right where you want to be. it is my poinion that guys runnung above 250 at the track are the only ones whou would benefit fron an oil cooler. oil temps in the 200 and less all the time are not what you want. once again just my poinion.
Old May 14, 2006 | 01:56 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
low 200
Old May 14, 2006 | 02:09 AM
rikhek's Avatar
rikhek
Temps you guys are seeing aree VERY low regarding the use of a LS1/LS6. You get a warning message in the DIC when you see 300 degrees. Head over to the autocross/roadracing forum and research this issue.
I typically see 285 running at Hallett, a road course. There is discussion that once you see the temps I'm seeing it might help to get a cooler. Many say it's not an issue at 285, others disagree.
The temps you're seeing are VERY acceptable. Don't waste your money if all you do is street driving.
Rick
Old May 14, 2006 | 08:25 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Rick
Thanks everyone for the posts.
Rick I appreciae your more detailed post and your temps, makes me feel better.
Old May 14, 2006 | 08:32 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
As I have said hundreds of times... the LS/X engines have a sweet spot.... 190 to 200 coolant and 200/210 oil... keeping the coolant in the sweet spot helps to keep the oil where it should be... too cold of oil is not what you want...too cold decreases flow , lubricity, internal integrity and causes power loss.
knowing the right numbers is key.... hotter oil produces more power... too hot causes thermal breakdown and shear..too hot is 280.
if you can keep both the coolant and the oil in the sweet spot, the car runs right.
Take it or leave it....
Bill aka ET
Old May 14, 2006 | 09:59 AM
Bill Dearborn's Avatar
Bill Dearborn
Rick
Leave the stock thermo in the car and clean the radiator inlet and don't worry. Your temps are in the correct range and will not adversely affect your engine. I have a Ron Davis Racing Radiator in my Z with built in engine oil cooler and the stock thermostat. Before I added a thermostatically controlled oil bypass valve my coolant temps would run at 200 and oil temps would run at 230 after 40 minutes of WOT on the track on a 85+ day. With the 180 degree bypass valve which determines the amount of oil flow through the oil cooler the oil temp runs about 265 now and the coolant temp has increased about 5 degrees. The setup includes a remote mount oil filter so I am running about 8 quarts of oil when I add the extra quart for the track.
By the way when I ran the stock cooling system the coolant would hit 230 and I saw 313 on the oil (no alerts from the car) under similar situtations.
Bill
Old May 14, 2006 | 03:46 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Bill aka ET
Again thanks Bill! I appreciate the lesson, I seriously thought that my oil was a bit to warm, but all this time my oil has been in the sweet spot! Boy am I stupid!
Old May 14, 2006 | 03:47 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Bill
Bill, I just recently did a heads and cam swap and I cleaned the radiator and condensor out really good! Thanks.
Old May 15, 2006 | 01:34 AM
Dirty Howie's Avatar
Dirty Howie
Bill
Bill
I have an EOC in a Dewitts.
Please checkout my thread in track section and tell me what you think: http://forums.corvetteforum.com/show....php?t=1364036
DH
Old May 15, 2006 | 01:40 AM
Dirty Howie
Bill aka ET
Now that things are warming up here in SoCal......my coolant is running 180 on freeway. Oil is hitting 198-210.
But I am hitting 270-285 oil at the track......2hrs every 5 weeks or so. I have large radiator with EOC. Should I stay with Mobil1 5-30. Should I be saving up for new engine ????
Thanks in advance for your input........
DH
To Oil Temp...
