do C6 calipers fit the c5's?
Old May 15, 2006 | 05:49 PM
gottiman's Avatar
gottiman
Default do C6 calipers fit the c5's?
Hi guys do the c6 calipers fit on a C5 without any modifications other then the wheel spacer. Can i just swap them out and go? -Tom
Old May 15, 2006 | 07:33 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
The base calipers on the c6 are the same caliper with the lettering changed. Nothing else changed.
Old May 15, 2006 | 09:25 PM
NoOne's Avatar
NoOne
The C6 caliper is functionally different, but not dimensionally.
It is 30 percent stiffer than the C5 caliper and less prone to flex.
Old May 15, 2006 | 10:56 PM
gottiman's Avatar
gottiman
really, i was not aware of that. SO in that case, is there any benefit to upgrade to c6 calipers, or should i just power coat my c5 calipers, and put the c6 rotors on my car?
Old May 16, 2006 | 02:36 AM
ICaughtVetteFever
Where did you get this info? Even the c6 Z06 brakes are not better than the stock C5s
Old May 16, 2006 | 02:45 AM
George8211's Avatar
George8211
I can tell you... the Base C6 Rotors fit
I'm told by PBR that the metal is better, and they are uni-directional.
Old May 16, 2006 | 05:00 AM
NoOne's Avatar
NoOne
From the GM Engineer that works on the program, I goto HPDE's with him.
Its also documented on alot of the GTO websites since the GTO used the C6 caliper before the C6.
I would not upgrade actually. They stiffened it up to fix the tapering problem with the caliper but when swapping out track pads on a buddy's 06 GTO even after 8k moderate miles the pads were still tapered.
The Z06 caliper is far superior, its the pad that is the problem.
Old May 16, 2006 | 06:23 AM
jdmvette's Avatar
jdmvette
Night Owl for life
if you want c6 z51 rotors you need the mounting brackets from the c6 z51 calipers.
Old May 16, 2006 | 08:02 AM
NoOne's Avatar
NoOne
I guess I should expand a bit on what I said too.
How much are the C6 calipers?
If the C6 caliper looks the way you want it to look and is close in price to powdercoating your current caliper then the C6 caliper might be easier.
It is beefier, I can tell that from just holding it in comparison to my c5 caliper.
Old May 16, 2006 | 08:31 AM
Blue Lightening's Avatar
Blue Lightening
I stuck C6 Z06 brakes on my C5 and couldn't disagree with you more. I am wondering on what facts you base that statement on?
Old May 16, 2006 | 08:51 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
there is a member that did the C6Z swap last fall, and lately a few more; the C6Z calipers bolt directly to the knuckle, the orig. calipers AND brackets are not used from the c5
Old May 16, 2006 | 08:59 AM
Blue Lightening
You are correct...the only thing that needs to be modified is the brake lines.
Old May 16, 2006 | 12:47 PM
Bill Dearborn's Avatar
Bill Dearborn
If they reduced caliper flex to zero they wouldn't cure the major cause of tapering on the C5/C6 caliper. Most taper and the cause of the long pedal when pushing the brakes hard occurrs from one end of the pads to the other. The inboard pad will be thinner at the top of the caliper (viewed vertically on the axle) and the outboard pad will be thinner at the bottom. This happens when you hit the brakes and the caliper twists just a bit on its mounting pins as it resists the rotation of the rotor. This causes uneven pad wear because the caliper is now positioned diagonally to the rotor. Once you lift off the brake the caliper rotates back to its normal position and the pads/pistons are knocked back so there is increased piston travel required the next time the brakes are applied.
Caliper flex causes a taper that appears across the pads from the inside (thicker toward the hub) to the outside (thinner toward the tire). This taper isn't good but doesn't cause long travel on the brake pedal (some people think this is fade or boiled fluid which it isn't).
Bill
Old May 16, 2006 | 03:28 PM
ICaughtVetteFever
Do a forum search, everyone I saw that did the swap said about the same on the street and worse on the track. I would like to try a set myself, but backed out when I heard that.
Old May 16, 2006 | 03:49 PM
Blue Lightening
I can't speak for the track, but I did the switch and am quite impressed the C6 Z06 brakes on the street. You can believe that if you want to, but I'm not buying the that some people have said which was the same as saying that GM put worse brakes on the C6 Z06 than what is on a stock C5.
I think they were priced very well, have been quite happy with their performance, like the way they look and would do it again.
Old May 17, 2006 | 05:32 AM
NoOne's Avatar
NoOne
Its not the caliper, its the pads.
For the track the pads aren't upto the task and right now it costs you $400 for a new set of pads, even the new Carbotechs that are supposed to be coming out for the track.
At $400 a pop for street/track pads that is what makes it a "bad" setup.
I'd be all over this myself if there was a decent track pad out there at a reasonable price.
Anyone know if the Z06 has the same sized MS as the C6?
To do C6 calipers fit the c5's?
