Replacing z06 shocks Article
Old May 16, 2006 | 10:52 AM
badaz06's Avatar
badaz06
Default Replacing z06 shocks Article
Does anyone have a link on this? I know one guy had an excellent article with photos...but I cant find it. Any help would be appreciated!
Jeff
Old May 16, 2006 | 10:56 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i've got a car coming in this afternoon for a set, easiest way to do it is with some 'S' hooks or long zip ties(thanks 6spd98) to compress the shocks for both removal and install or remove the upper control arms on the front
Old May 16, 2006 | 12:24 PM
badaz06's Avatar
badaz06
yeah...I was trying to find that article to show it to someone..as well as for my own 411. He was saying something about a tool that compresses them that would be better/safer.
Dunno
Old May 17, 2006 | 09:22 PM
badaz06's Avatar
badaz06
bump
Old May 17, 2006 | 11:10 PM
ThePizzaC5's Avatar
ThePizzaC5
Dunno
The zip ties really aren't all that un-safe. The shocks don't just fling open once they get loose, they extend slowly, so you'll be good to go. Just make sure you use good ones and they won't break, so you'll be less-likely to start cussing.
Old May 18, 2006 | 07:08 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
The zip ties are very easy to use. When you release them, the shock slowly extends, so even if a zip tie broke, it wouldn't be a big deal. Before I changed my shocks I called around to all the auto stores for a tool to compress the shocks. No one had heard of it and all said to use a piece of wire or zip ties. It really is very easy.
jeff
Old May 18, 2006 | 09:15 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Zip ties, rope, anything that will tie together.
If it comes undone and the shock extends (which it does slowly)... just push it back in. Might have to use a muscle or two and/or put your weight behind it, but you can push it back in.
Old May 18, 2006 | 10:23 AM
JeffC5's Avatar
JeffC5
I was pretty nervous at first. For some reason I had it in my head that if the zip tie broke, the shock would spring out, hit me in the face, blind me and perhaps kill me. lol
In reality, it just slowly expands.
jeff
Old May 18, 2006 | 10:28 AM
JeffC5's Avatar
JeffC5
http://www.c5forum.com/diy/shocks.php
http://www.ls1howto.com/
Try these.
jeff
Old May 18, 2006 | 11:23 AM
DPG's Avatar
DPG
St. Jude Donor '06
compressing springs or coilovers may do that but not a shock. Its like the shocks on your hood. Those dont go flying through the hood everytime you open it
Old May 20, 2006 | 01:02 AM
badaz06's Avatar
badaz06
jeff
LMAO....actually I was visualizing the thing expanding and me looking at a huge hole in the fiberglass.
thanks for the links!
Jeff
To Replacing z06 shocks Article
