Has anyone had the problem with the top coating starting to peel or flake off. Looks like it is starting to travel. Any fixes? Car is driven every day and is kept in the garage.
cool60 :cool: :confused:
'98 Fairway Green Coupe 40k miles
'60 Tasco/White (As seen in Corvette Fever July 2001 Issue)
[Modified by cool60, 3:31 PM 8/24/2001] :cool: :cool:
Several forum members have mentioned this in the past. There is no fix for it. If you are under warranty GM should replace the top. Thankfuly this has not happened to me "yet."
Hi: Mine got so bad and ugly I don't use it anymore. Tried everything to clean it up (compound,etc. etc. etc.) and only succeded in making it look worse :mad . I've not heard about one time that anyones been able to fix it once it starts to go. Replacement seems the only way. (If you're lucky and under warranty). Good Luck :D :D :D
I suppose its redundant to ask if anyone has any tips for small cracks starting to form at the passenger side near the edge. I am out of warranty and out of luck.
Dealer replaced mine under warranty. It is a factory defect and the dealer should replace it. I hope the one they replaced it with doesn't do the same thing.
