How to unlower a 2000?
May 16, 2006 | 09:54 PM
The 2000 FRC I just bought was lowered and Im not much into that. How do I go about bringing it back up to where it should be? Im also going to take the Penske adjustable shocks off. They are listed on the for sale section.
http://forums.corvetteforum.com/show...light=2000+frc
May 17, 2006 | 01:02 AM
May 17, 2006 | 03:00 AM
St. Jude Donor '07-'08
Tighten the bolts on the leaf spring in back, and losen the ones on the leaf spring in the front.
May 17, 2006 | 03:24 AM
Pm sent...
May 17, 2006 | 09:38 AM
Is there stops on the bolts you tighten and losen?
May 17, 2006 | 09:56 AM
Cruise-In VII Veteran
no stops; you will not loosen any of them, count about 8 threads showing the rear or 1 inch of the bolt showing from the top of the nut
on the front, tighten the adjuster so 1.125 inches of the thread are showing
the rear is simple 18/21mm, front often requires jacking the spring to relieve pressure, 10mm 6 POINT ONLY, USE BOX END
May 17, 2006 | 10:22 AM
Thanks for the reply! Looks like my weekend is cut out for me
May 17, 2006 | 10:26 AM
Quote:
Shouldn't take more than 1.5 hours, as long as the front bolts haven't frozen in place....
May 17, 2006 | 10:44 AM
here's a pic of the front, the bottom of the rubber pad rests on the top of the control arm
the rear utilizes a different setup, the spring is on the bottom of the control arm opposed to the top like the front
May 17, 2006 | 12:11 PM
Thanks for the pics Steve this is going to help a ton!
May 17, 2006 | 08:28 PM
Could you tell me what the normal length of the back bolt is? It looks longer then the one you show.
