how do i raise my 2000 vette
any ideas.
sorry for any mistake this is my first post and i need some help.
again thanks for all your help
The manufacturer's Trim Height Specifications differ for each of the C5 suspensions; i.e., FE1, FE3 (Z51), F45, etc. The car needs to be on a level surface such as an alignment rack with both doors and the hood closed and the trunk/hatch rear area empty, etc., etc., etc. Both the front and rear trim height are then measured from the lowest point of the ball joint to the center of the front side of the lower control arm mounting bolt using a GM J-Tool 42854.
I don’t have access to a model year 2000 GM Service manual. However, if you want to do this yourself, post your suspension type. Then perhaps someone here with the 2000 Service Manual can provide you with the proper procedure and correct specifications/tolerances specific to your model year.
On the other hand, if you're not concerned with the factory specs, perhaps someone whose car is stock height with the same suspension as yours can provide you with some measurements. But again, anything they provide will not be to factory specs.
Too, you will want to have the car realigned once you have reset the trim height.
Good luck!
Mine used to scrape pulling in at stock ride height. Then i started backing in and had no problems. Since then i have lowered it a good inch and still have no issues as long as i back it in.
anyway thanks for everyone help and answers,
roger
