Quick ? on PRC Spring kit for those that have changed
Old May 19, 2006 | 10:07 PM
N2O4YOU's Avatar
N2O4YOU
Default Quick ? on PRC Spring kit for those that have changed
I recieved my TSP Torquer v2 and PRC double spring kit today and am swapping the cam. I noticed that all of the new valve seals are brown. Is this normal. The how to I am using says the intake seals should be black and exhaust seals should be brown. Those that have swapped their springs with the PRC's , were all of the seals brown?
Old May 19, 2006 | 10:21 PM
RoadRebel's Avatar
RoadRebel
YES
RoadRebel's Avatar
RoadRebel
YES
Now get back to work!
Phil
Old May 19, 2006 | 10:32 PM
LETHL_C6's Avatar
LETHL_C6
Same here.....
Old May 19, 2006 | 10:34 PM
N2O4YOU's Avatar
N2O4YOU
Thanks! I try and get a vid up once I get it fired up. Should be done tomorrow. It hasn't been too bad so far. The steering rack was a PITA. Hopefully it goes together smoothly. Thanks again.
Jim
Old May 19, 2006 | 10:40 PM
LETHL_C6's Avatar
LETHL_C6
Jim
If you havent removed it, take off the front swaybar. Makes moving the rack around a lot easier. I removed mine with it in place but decided to take off the swaybar before I put it back in....... glad I did!
Old May 19, 2006 | 10:48 PM
N2O4YOU's Avatar
N2O4YOU
Took swaybar out but thanks for the tip.
To Quick ? on PRC Spring kit for those that have changed
