Wierd problem with RAP feature on radio
When I turn off the car with the door closed and radio on, the radio stays on until the door is opened.
Normal so far...
But, when I close the door, the radio comes back on.
Then when I hit the lock button on the remote, the radio turns back on.
As I am writing this, I will have to see if it still does it if my Top Down module is unplugged.
Anyone else ever had this happen?
My radio will stay on after ignition is turned off but once I open the door it will turn off. Radio will come back on when I hit the unlock door button.
You probably need to go tho web-site and down load instructions to reprogram. I had to do this after changing rear seal (coupe) my windows would not go up and kept coming down because new seal changed the window close height.
Last 4 digits on white serial number is you pin number.
