Scary weird knocking sound HELP
Old May 20, 2006 | 04:02 PM
babensteve's Avatar
babensteve
4th Gear
Default Scary weird knocking sound HELP
My 97 coupe has 85k on it and just started making a metallic clanking sound under acceleration and braking. Here are the weird symptoms:
1) Under acceleration at any speed it makes the sound.
2) If I accelerate in reverse there is no sound but the sound come when I brake
3) If I let the car roll down hill backwards in neutral with the engine running and brake the sound happens
4) If I roll backward with the engine off and brake the sound does not happen.
5) If I rev the engine in park the sound only happens when I let off of the gas and the engine is going back to idle.
6) there is no sound at idle
7) The oil pressure display reads 130 psi and gauge is pegged
Old May 20, 2006 | 04:18 PM
SpeedyD's Avatar
SpeedyD
That's a stumper! May be more than one problem. I'm thinking the oil pressure gauge isn't related. Did they start at the same time?
Old May 20, 2006 | 04:25 PM
babensteve's Avatar
babensteve
4th Gear
Close to the same time. I have read on the forum about the sender going bad.
Old May 20, 2006 | 06:25 PM
babensteve's Avatar
babensteve
4th Gear
move up
Old May 20, 2006 | 06:50 PM
SpeedyD's Avatar
SpeedyD
Yeah, the sender is definately a problem in these cars, so that's why I'm thinking they aren't related. I'm sure someone will step in and help out. Wish I could, but it just seems really strange. Good Luck!!
Old May 20, 2006 | 07:37 PM
NSTG8R's Avatar
NSTG8R
any codes?
Old May 20, 2006 | 11:03 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Is the noise coming from upfront or in the rear ?
Do you have a stick or auto ?
It sounds like the problem is somewhere in the drive train as the noise only occurs when the engine and transmission are engaged.
Have you jacked up the car and inspected the drive - line. If you have a manual, you might want to pull bell-housing cover and inspect clutch area and front of torque tube.
Old May 20, 2006 | 11:16 PM
babensteve's Avatar
babensteve
4th Gear
It's an auto and it now sounds like the sound is coming from the bottom of the engine near the firewall. Need to pull codes tommorrow
Old Jun 4, 2006 | 11:40 PM
Sammy_C5's Avatar
Sammy_C5
Sammy_C5's Avatar
Sammy_C5
To Scary weird knocking sound HELP
