nitrous + reduced engine power problem
Old May 21, 2006 | 05:00 PM
123sugey's Avatar
123sugey
Dig
Default nitrous + reduced engine power problem
I Have A Zex Nitrous Unit. The Last 3 Times I Used It On My 97 A4 Vett, It Put The Computer In Limp Mode And The "reduced Power" Light Comes On And Limits Power.
I Have Been Using This System For 7 Months With No Problems. Its Only A 125 Wet Shot , Throtte Activated System..............
Old May 22, 2006 | 01:04 AM
vetred's Avatar
vetred
EH,..............Thats "spray" you say??????? A couple of weeks ago a friend with a stage three blew his head gaskets and to be honest a whole lot more but thats where Id start
Old May 22, 2006 | 01:03 PM
vettes4fun's Avatar
vettes4fun
Check to make sure that you are spraying Nos and the fuel out the jet. It sounds like your not spraying nos and your flooding the engine with fuel. Make sure the the sol are opening.
Old May 22, 2006 | 04:10 PM
123sugey's Avatar
123sugey
Dig
That Sounds Correct About The Nitrous Solenoid Not Opening.
Because As Soon As I Pushed The Safety Activation Button, It Went Into Limp Mode.
Besides That. The Car Is Running Ok
Old May 22, 2006 | 04:29 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
What codes are you getting?
If you don't know how to retrieve your fault codes just follow this link:
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old May 22, 2006 | 05:23 PM
ArKay99's Avatar
ArKay99
First things first.
P1514?
To nitrous + reduced engine power problem
