Walbro 255 install question???
Old May 21, 2006 | 08:43 PM
red12secz28's Avatar
red12secz28
Default Walbro 255 install question???
I need to replace my fuel pump. My question is do I need to use the stock c5 fuel strainer/sock or use the one that comes with the pump. From what I have noticed is that the stock strainer is large and flat. It looks like it would help aid the fuel pump in its operation.
Old May 22, 2006 | 11:49 AM
red12secz28
anyone ttt
Old May 22, 2006 | 01:04 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Im confused by your post because the only options I have heard about for us are the LPE and Racetronix pumps that come with buckets. Sounds like you picked up a Walbro and fit it into the stock bucket?
In any case I would use the C5 specific filter sock and not the generic one that came with the Walbro you got. Thunder Racing has them. I got a new one when I got my Racetronix.
Old May 22, 2006 | 01:58 PM
sonicbaloo's Avatar
sonicbaloo
St. Jude Donor '06
We sell the Racetronix with new filter socks.
Chad
Old May 22, 2006 | 09:12 PM
red12secz28
I allready have a walbro 255. Just wanted to know if it was better to use a stock style strainer sock. Where would be the best place to get one?
Old May 24, 2006 | 02:27 PM
SmoothFRC's Avatar
SmoothFRC
You can order a sock from LPE i think..... should be around $20
Old May 24, 2006 | 07:59 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
I replaced the stock with a Walbro 255 for an LS1. The sock was different, but it fit in the can, the electrical connector was identical and I have had no problems with it. I saw no way to swap the stock sock to the Walbro 255.
To Walbro 255 install question???
