Low Oil Level, Dipstick Useless, Need Help Please
Old Aug 25, 2001 | 02:28 PM
Speedway's Avatar
Speedway
Default Low Oil Level, Dipstick Useless, Need Help Please
Hi all -
Well, at 3000 miles, my low oil level warning came up on the DIC. First thing, checked the dipstick. Anyone know how to read this thing? For now, I will run out and throw a quart of mobil 1 in.
Thanks for the help.
Old Aug 25, 2001 | 03:01 PM
hal26's Avatar
hal26
Default Re: Low Oil Level, Dipstick Useless, Need Help Please (Speedway)
Try the owners manual.Park the car on level pavement.I check mine when the engine is hot,I allow the oil to settle for 2 or 3 minutes I remove the dipstick and carefully wipe it off with a clean paper towel then I insert it all the way.At this point I slowly remove the dipstick, being very careful not to drip any oil.If it is not up to the full mark I will add one fourth of a quart of oil,again allowing a couple of minutes for the oil to settle before rechecking.Do this until the oil level reaches the upper mark.Do not overfill.Drive the car then recheck.I check my oil every 250 miles .You should too! :lol:
[Modified by hal26, 7:02 PM 8/25/2001]
[Modified by hal26, 7:03 PM 8/25/2001]
Old Aug 25, 2001 | 03:15 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The message can come on from being 1 qt or more low.Have you done the first oil change yet.The 2001 will take 7 qts...
Old Aug 25, 2001 | 03:41 PM
goldman's Avatar
goldman
Many people report it is easier to read the dipstick if you lightly sand the "reading" area so it is slightly "scuffed" & better "holds" the oil.
Cool oil seems easier to "read" also.
Old Aug 25, 2001 | 04:35 PM
SRitger's Avatar
SRitger
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
BE WARNED: Once the DIC shows "LOW OIL LEVEL", you must let the engine cool down completely after adding oil, otherwise that message will keep popping up every few minutes. Don't ask me why it does this...it just does...drove me crazy last year in BG. Ideally, you should let the engine cool overnight.
Cheers,
Steve
Old Aug 25, 2001 | 05:43 PM
Scruffy's Avatar
Scruffy
Speedway, Try emory cloth to rough up the area between the two holes. IT does make it easier to read. I check my oil AFTER the car sits over night. That is how much oil is in the crankcase. Oil seems to take a long time to return down to the crankcase on the LS1.
To Low Oil Level, Dipstick Useless, Need Help Please
