codes
Old May 23, 2006 | 10:06 PM
redbob's Avatar
redbob
Default codes
Help what are these Codes P1571,0327,0719,0748????
Old May 24, 2006 | 12:30 AM
PierEagle's Avatar
PierEagle
You can go to WWW.corvettedoctor.com and get the list of all codes you may see on the DIC. Click Technical Data Base then, I believe it's ECM Computer Codes and then the year.
The codes you posted:
0327 - ?
0719 - Brake Switch Circuit Low Input
0748 - Pressure Control Solinoid Circuit
1571 - ASR Desired Torque
Cheers
Old May 24, 2006 | 12:57 AM
SFVetteman's Avatar
SFVetteman
P0327 Knock Sensor Circuit Low Voltage
You can also Google for the info. Just punch in the code followed by DTC. Many times it will lead to a solution
To codes
