HVAC lights out
Old May 25, 2006 | 10:09 PM
Wickd1's Avatar
Wickd1
Default HVAC lights out
Hello im a new Vette owner and i noticed the other day that my HVAc lights dont work, all of the buttons work fine, and at night i can see barly the lights , but other then that they dont work , could it be a fuse, bulb, or is this a dealer fix>
? anyone else experiance this before?
thanks
Bluewasp
Old May 25, 2006 | 10:22 PM
DngrZne's Avatar
DngrZne
http://forums.corvetteforum.com/show...highlight=hvac
Old May 25, 2006 | 11:27 PM
rws.1's Avatar
rws.1
Very common problem.
Most likely case is bad cold solder joints...
If you are comfortable cold soldering a circuit board you can do it your self... follow the links in the post above.
IF not, a CF member Mangitial.... David Ruberg will fix for you for about $50 including the shipping back to you and a 5 year guarantee.
e mail digitalguy_1@charter.net
Old May 26, 2006 | 09:08 PM
DngrZne's Avatar
DngrZne
If it's the display that's out, it's most likely the solder connections. If it's the backlighting for the buttons and red/blue displays then most likely the bulbs are burnt out, which you can fix by following the link I posted above. The problem is that GM used tiny 12V incandescent bulbs, rather then LEDs to do all the backlighting, so they will go bad eventually. The status lights on the buttons are LEDs, however, so they shouldn't be an issue.
Chris
Old May 27, 2006 | 12:02 AM
rws.1's Avatar
rws.1
Depends which problem you have....
To HVAC lights out
