Head and cam package???
http://texas-speed.com/shop/item.asp...d=174&catid=49
http://texas-speed.com/shop/item.asp?itemid=649
What does that look like to yall?????
I would get the stock .550 lift springs on the heads and then put the 918s on when I got the cam package in. does this look liek a good idea???? im also going to use the XE 224/224 cam
Give TSP a call and explain what you expect out of the cam and I'm sure they can help you select which one is best for your application.
Good luck,
Mark
