Clicking sound while lifting rear
Old May 26, 2006 | 08:52 PM
Mark S.'s Avatar
Mark S.
Default Clicking sound while lifting rear
A few weeks ago when I changed my oil I was at the stage of lifting the rear ( 2 and half ton jack has a head which spans the two ribs of the rear crossmember) I heard a slight clicking noise as I was nearing the end of my jacking... I then place some ramps under the rear tires and continued with the oil change process.
Lately, there has been a lot of talk about not placing the jack in the center of the crossbeam and then raising the rear.
Well, I went ahead and used a forum member's method of using a 6x24x1 wood piece and gave it shot. After a few pumps of the jack I heard a clicking noise with each pump...so I stopped...is it possible that my rear crossbeam is about to crack or has cracked? Does anyone else hear any clicking/creaking when lifting the rear with their jack?
Old May 26, 2006 | 10:24 PM
tiojames's Avatar
tiojames
Default clicking
I doubt that your cross member is cracking or making noises. I have always jacked up my car(front and rear) in the center of the crossmembers and have had no noises or problems. It may have been the wood cracking or creaking.
Old May 27, 2006 | 07:03 AM
Mark S.'s Avatar
Mark S.
James, I did remove the wood and made direct contact with my jacking head (which does span the two ribs of the crossbeam) and it continued to make the same noise. So I don't believe it's the wood. It really sounded more like a clicking noise more than a creaking one. I made a visual inspection of the crossbeam (as best I could) and I couldn't see any cracks...
Problem is that for the past 5 years (about 11 oil changes -- only have 13K miles on her) I have been using direct contact with the jacking head in the center of the crossbeam to lift the rear during my oil changes...I hope this hasn't finally caused the crossbeam to weaken, etc. Recent posts by other members have indicated that it is not good to lift the rear by the center of the rear crossbeam...
Old Nov 1, 2021 | 10:41 AM
y0ung TcHalla's Avatar
y0ung TcHalla
I know this is old but any updates? I have lifted my car from the center a few times and wondering if I have caused any damage
Old May 9, 2023 | 12:15 PM
JCMDoug's Avatar
JCMDoug
This is happen to me, in fact if I take a quick turn it makes the snapping noise. So I go home jack up the car and hear the noise again. I shake everything I can think of inspect all the bushings I can see (shock, control arms) and find nothing. I put the car back on the ground and there it is again, the same noise (with the wheels touching the ground and almost all of the weight on them.) With the car sitting and me bouncing it up and down I can't make it snap or pop. The car handles normal, but one quick turn or sometimes a slight pot hole and it's back. Normal driving it's fine.
Last spring we changed the diff so the rear cradle was off the car. This Easter egg hunt is driving me nuts, I make take it to a shop with a four post lift so I can be under the car and have some move it so I can find the sound.
To Clicking sound while lifting rear
