Mem Seat Acting Up
Old May 27, 2006 | 09:41 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
Default Mem Seat Acting Up
Seat maintains set but will not slide back for easy exit when using FOB 1. Door switch for mem 1 does not activate easy out either.
Works fine with FOB 2.
Anyone had this problem? Possible solution?
Old May 28, 2006 | 03:04 AM
SpeedyD's Avatar
SpeedyD
If you click threw the options on your cluster the easy out is an option, make sure it is turned on. Other than that, I'm not sure, that was my problem, Good Luck!! Dan
