Changing brake pad, tools required?
Old Aug 26, 2001 | 02:36 PM
MJM's Avatar
MJM
Default Changing brake pad, tools required?
Already possess
Ramps
Jack
Jack stands
Torque wrench
New set of pads
What size C-clamps do I need?
What size or types of wrenches, etc. are needed (other than for the lug nuts)?
ex. caliper guide pin bolt
any other nuts, bolts, etc.
Any tips?
Old Aug 26, 2001 | 03:34 PM
Morpheus's Avatar
Morpheus
Default Re: Changing brake pad, tools required? (MJM)
My recommendation for tools is a 16mm open or combination wrench, a ratchet with 15mm socket to remove the caliper bolt, and rather than the C clamp, get yourself a Channelock tongue and grove plier along with a small and thin piece of wood to push in the caliper pistons.
It's quite effortless.
Old Aug 26, 2001 | 03:57 PM
gpflepsen's Avatar
gpflepsen
Cruise-In II Veteran
Default Re: Changing brake pad, tools required? (Morpheus)
If you're going to he track and need a kit for pad changes, just have this:
15mm combo wrench
16mm combo wrench
8" C-clamp
Removable Lock-tite
The C5 has to be one of the easiest vehicles to change brake pads on,
Old Aug 26, 2001 | 05:45 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You dont need a piece of wood... just use one of the old pads.. to push the pistons back...
Old Aug 26, 2001 | 10:06 PM
99HT's Avatar
99HT
It is always recommended that you open the bleeder valve before forcing the calipers open. If your pads have seen a lot of abuse, there will be a lot of sludge behing the pistons. You do not want to force this crap back up the tubing.
Old Aug 28, 2001 | 11:52 PM
MJM's Avatar
MJM
Thanks for the advice
To Changing brake pad, tools required?
