How do you install these things? I know they are a direct plug in but when I looked I am sure you must remove something.What do I do to get them in? Thanks a lot
Re: Install Question on Xenon Plasma Lights (GaryZ06)
Are you referring to the foglights or driving lights? The driving lights you have to turn the connector and then it will pull down. I understand the foglights are very similar in that you have to twist them out. The DRL are very easy to replace. I have done mine takes about 15 minutes.
Re: Install Question on Xenon Plasma Lights (UR2SLW)
I am talking about the headlights(high/low beam) What connector.When I looked with the lights on and up there seems no way to get to them.I am pretty new to these cars.Thanks.
Are they the same wattage as stock?
Anyways, you remove the headlight bezel to reach the lights, its a tight fit. The stock ones twist and pull out, new ones pop in and twist to lock in. The ones I bought from an ebay seller pluged right in.
