Easy to replace Left axle seal?
Old May 28, 2006 | 11:08 PM
servohead's Avatar
servohead
Default Easy to replace Left axle seal?
I've had the rear end apart, somewhat, before to replace the left rear wheel bearing, but didn't pull the axle. Now as a separate issue the left axle seal is leaking considerably. Is that a simple job to replace the seal? Just pull the axle, pop the seal out and tap a new one in? Or do you really need GM special tools?
Old May 29, 2006 | 12:43 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
yes, that's it; w/ the wheel bearing off, your right there
Old Jun 1, 2006 | 06:13 PM
servohead's Avatar
servohead
I wonder. I hear an awful lot about diff leaks.... I'm 99% sure it's the left axle seal on my car, (and I'm a mechanic for what that's worth...), but it seems people have been tricked before.... There isn't like a vent right above the left axle seal, or some other ironic place of leakage in that viscinity is there? Just wondering....
I like replacing parts anyway... it's a win win situation.
To Easy to replace Left axle seal?
