B&M Precision Shifter Rattle Fix
Old May 29, 2006 | 01:32 PM
lloaf's Avatar
lloaf
Default B&M Precision Shifter Rattle Fix
I seem to remember that someone had a fix for this, using hard foam or something like that. Can't find it in Search. Anyone know the fix ? Thanks
Old May 29, 2006 | 05:53 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Yours is the first post I've seen where someone said they had a rattle with the B&M Precision shifter. Mines been quiet since installation, perhaps somebody will chime in to help you out.
Old May 29, 2006 | 10:57 PM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
you can put a piece of foam/rubber in between the shifter and the body of the vehicle. this should stop your rattle. did you use lock tight when you tighten up the screws
Old May 30, 2006 | 12:15 AM
JTS97Z28's Avatar
JTS97Z28
Humm, my new B&M 45044 seems to make a weird rattle as well. I would also like more info on this. Where exactly do you put the foam ?
To B&M Precision Shifter Rattle Fix
