Battery charging help please....
Old May 29, 2006 | 05:08 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default Battery charging help please....
I left the interior lights on last night on my 2004... (I know, I'm a dumbazz)and of course the battery ran down...duh(I'm a dumbazz)........can I charge the battery in place (I'm a dumbazz)or should I disconnect the battery first? Is one hour enough or should I charge it 2 hours?(again, I'm a dumbazz).
Thanks for your help,
Yours truly,
Dumbazz
Update...just found this informative section in the owner's manual...
"Battery Run-Down Protection"
Your vehicle has a feature to help prevent you from draining the battery in case the underhood lamp, vanity mirror lamps, cargo lamps, reading lamps, console or glove box lamps are accidentally left on, they will automatically timeout after about 15 minutes. To reset it, all of the above lamps must be turned off or the ingition key must be ON."
Way to go GM
Maybe Evil Twin can chime in with some help here
Old May 29, 2006 | 05:13 PM
mayberry's Avatar
mayberry
I have charged mine in place in the past with no adverse reactions. Since my C4 sits all the time it gets charged quite a lot, but I've done it on the C5 as well.
Old May 29, 2006 | 05:15 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thanks...so 1 hr or 2 hr charge?
Old May 29, 2006 | 06:02 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Over 100 people viewing here...anyone have some kind of clue?
Old May 29, 2006 | 06:03 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Just read your post on your starting problem...and I thought I had a problem
Old May 29, 2006 | 06:26 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
You sure have alot of posts for a dumbazz! LOLOLOLOL
jeff
Old May 29, 2006 | 06:37 PM
pinot's Avatar
pinot
We've all been there.
If you are gonna bring that puppy back in 1-2 hrs that means you must have a big charger. To be on the safe side pull it out. A battery tender is one thing, but it that much current is going in I would isolate the batt from the more expensive stuff. you don't want a little issue becoming a big one.
Pinot
Old May 29, 2006 | 06:54 PM
mayberry's Avatar
mayberry
Tell me about it. Trying my last option now with a BCM relearn. Don't know where to go if that doesn't work other than to the dealer. Good luck with yours.
Old May 30, 2006 | 09:50 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
jeff
Thanks for the comment Jeff ...how ya doin bud?I also see you put the Z06 screens on like I did to mine. ...and how many miles do you have on your puppy now?
BTW...
Update...I put a one hour charge on the battery and took her for a ride and now everything is back to normal...and yes I am a dumbazz for leaving the interior lights on
Old May 30, 2006 | 09:52 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thanks guy...got my smaller problem solved with a 1 hr charge...it was my own fault for leaving the interior light switch on Hope you get your fixed soon
To Battery charging help please....
