Stalling when lifting throttle
Old May 29, 2006 | 06:00 PM
connellyh's Avatar
connellyh
Default Stalling when lifting throttle - Fixed I think
My 99 is stalling when I lift my foot off the throttle. It happens when lifting after cruising, accelerating or coasting. The RPMs drop way low and the car dies. I can feather the throttle and keep it running. I can get the RPMs to stablize and the car will idle at 350-400. After 15-20 seconds, the idle pops back up to the normal 750 RPMs.
This all started after I disconected the battery for about 7 days. Everything else works fine. I figured it would have worked itsefl out by now, it's been a week. I've even tried disconnecting the battery to reset the computer. No luck. Any ideas?
Last edited by connellyh; May 31, 2006 at 03:48 PM. Reason: problem possibly solved
Old May 29, 2006 | 08:18 PM
cenzo's Avatar
cenzo
Codes??
Old May 29, 2006 | 08:57 PM
azmusclecar's Avatar
azmusclecar
TPS? Throttle position sensor?
Old May 29, 2006 | 09:38 PM
connellyh's Avatar
connellyh
I haven't checked codes. Will do tomorrow.
I didn't think it was the TPS because the only thing that changed was the battery being disconnected. It ran fine before that.
Old May 29, 2006 | 09:40 PM
sugarwolf's Avatar
sugarwolf
Make sure there is no un metered air getting in to the intake. I had my MAF hose come loose and did the same thing. So go check to make sure there is no leaks after the MAf to intake
Old May 30, 2006 | 03:49 PM
connellyh's Avatar
connellyh
There are no codes, no air leaks, no vaccuum leaks, no loose wires. Another thing I've noticed, when I come to a stop the RPMs jump back up to 700ish within 1-2 seconds. When I first start the car, it idles at 900 RPMs and slowly falls down to 700ish.
Here is the sequence of events:
car ran fine - disconnected battery - car sat for 1 week - reconnected battery - stalling problem.
Nothing else was touched. The reason I disconnected the battery is because I have the dreaded phantom battery drain and the battery will loose all of it's charge if it sits for a week.
Old May 30, 2006 | 06:39 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Just a shot in the dark, but maybe the battery issue is unrelated. On 4.6 SOHC Fords, this problem was frequently due to problems with the idle air bypass -- either a failing idle control motor or crap in the passage itself (i.e., actual air flow didn't match what the computer thought it commanded). I realize the LS1 isn't set up like the 4.6 mod motor, but the same principles still apply.
p.s. I've assumed that you've checked and there's no problems with the throttle position controller harness -- a Q that came to mind when you talked about working on the battery, as the controller is right there below the battery, in front of the engine module.
Old May 31, 2006 | 03:51 PM
connellyh's Avatar
connellyh
I think I found the problem, dirty throttle body. I guess the computer had compensated for the gradual build up of crud and when I disconnected the battery, it lost the learned compensation. On just 2 litle short drives, the car didn't stall. RPMs never dropped below 600. The moral of the story is "Always look for the free and easy fix first."
To Stalling when lifting throttle
