need help getting off both wiper arms
If you still can't budge them, you can rent a special wiper arm puller at Autozone or similar stores.
The two prongs go between the wiper arm and windshield with the wiper motor threaded post between the prongs. The threaded post of the tool pushed down on the threaded post of wiper motor. Easy and it takes about 5 seconds once you have the proper tool!
They should be about 10 bucks!
http://www.etoolcart.com/index.asp?P...OD&ProdID=6881
Reinstall it so that the taperlock is reengaged since the nut alone cant handle the torque from the motor and you wipers will eventually change positions especially if you are pushing something heavy off your windshield (like snow) although this is unlikely with your vette. Also, if you use the high speed setting for the wipers, this can cause it to move as well. The taper lock is there for a reason, not just to be a pain when you want the wiper assembly removed!
I had a bear of a time getting mine off last year to touch up the paint on the arm. With a little motion, side to side and up and down they came off pretty easy. I admit that the "puller" shown below might make the job easier you don't "need" it to get them off.Paul
D*MN rocks -
