o2 sensor extenstions
Old May 29, 2006 | 10:33 PM
greg 6746's Avatar
greg 6746
Default o2 sensor extenstions
Will be installing headers soon need to know where to buy o2 sensor ext. and high heat tape to wrap the wires.
Old May 29, 2006 | 10:38 PM
Phil97SVT's Avatar
Phil97SVT
Why do you need O2 extensions?
- TPIS & Kooks work fine
- LG & Dynatech you use the rears with o2 adapters
Old May 30, 2006 | 01:44 AM
dwalker011's Avatar
dwalker011
Isn't this something that can be done at home? I used to do MD inspections at a Sunoco and my friend brought his 01' Cobra up for LT and X-pipe install. We ended up cutting the O2's, soldering in additional wire, and sealing with some heat shrink wrap. Worked perfectly. If you can hold a soldering iron, you can do this. Im sure there are some pitfalls to this method but it worked well for us. Somebody else can probably chime on this.
Old May 30, 2006 | 02:47 AM
MUKAK's Avatar
MUKAK
yep. or you could just buy them as plug and play from dynotech or LG
Old May 30, 2006 | 08:33 PM
berryj's Avatar
berryj
Greg, you won't need the rear ones as they can be edited out by a local tuner.
To o2 sensor extenstions
