AC problem, can someone shed some light?
Old May 29, 2006 | 10:53 PM
Sully1882's Avatar
Sully1882
Default AC problem, can someone shed some light?
never had any problems with my 2000 A4 coupe in any of the HVAC areas...until now. Three and a half hour trip and AC is working fine until it seems to be making a fluttering noise...kinda like a flag in the wind...and this is noticed after I turn it to max on the controls. Barely any air is coming out but what is coming out is very cold still. The display on the dual zone climate control shows it is at max but it is barely blowing. Got to where it was hot in the car and I shut the AC completely off and put the windows down. On the way home today about two hours into the trip it did the same thing with reduced function. What is the deal? I searched the forum for info on this and the blower motor and really found nothing. Any ideas and help would be greatly appreciated. Again in short, it works just fine for a few hours but then the function of the blower is decreased to very minimal. Next day everything fine again until a few hours of usage and then barely blowing again.
Thanks, Thomas
Old May 30, 2006 | 12:41 AM
Bill Dearborn's Avatar
Bill Dearborn
There may be a problem with the low pressure switch. The switch is set to shut off the compressor if the low side pressure goes below a certain point. This point usually equates to an evaporator temp of 36 to 38 degrees farenheit. If the switch allows the pressure to go too low the evaporator temp will drop below freezing and the moisture in the air will freeze and block air flow through the evaporator. Since this takes some time you would get the symptoms you are describing. You may also feel fine pieces of ice blowing out of the center vents.
Bill
Old May 30, 2006 | 09:52 AM
Sully1882's Avatar
Sully1882
Default that's an idea...
but any fix to that problem...???? Or any other ideas? Drove the car this AM to work and absolutely no problems with the AC on manual or Auto... and there was no problem with switching from low to high with how the AC was blowing. If it is the low pressure switch should I just leave it alone since I only only notice it on long trips or should I get it fixed now?
Thanks again, Thomas
Old May 30, 2006 | 12:31 PM
Sully1882's Avatar
Sully1882
Default ttt
ttt
Old May 30, 2006 | 02:42 PM
white90conv's Avatar
white90conv
Bill
I agree with this explanation. I have had evaporators freeze up and block the airflow. When you start to notice reduced airflow, turn off the AC but keep the blower running. The airflow should pick up indicating that the ice is melting.
Old May 30, 2006 | 03:07 PM
Sully1882's Avatar
Sully1882
Default low pressure switch....
ok ... then what is the correct way of diagnosing this problem or should I just replace the switch ?
Thanks so much for any help in advance,
Thomas
Old May 30, 2006 | 10:02 PM
Sully1882's Avatar
Sully1882
ttt
Old May 30, 2006 | 11:26 PM
white90conv
Thomas
I looked at the schematics and cannot find a low pressure switch (not saying it isn't there). The C4 had an adjustable low pressure switch. There has to be either a pressure or temperature switch in the evaporator to prevent freezing but I cannot figure this out for the C5. Sorry
Old May 31, 2006 | 11:29 AM
Sully1882's Avatar
Sully1882
ttt
Old Jun 1, 2006 | 10:36 AM
bobc997615's Avatar
bobc997615
Would an overcharge/undercharge of R134a cause the same problem(freezing)? Seems the R134a systems are much more sensitive than the R12. You just can't throw in a can of "freon" with the R134a. Ounces of R134a can make a big difference in performance either way.
To AC problem, can someone shed some light?
