I could be wrong, but here's what I was thinking: He's going from a larger MAF (01+) to a smaller one (98), therefore he'll need the rubber insert that makes the hole smaller...right?
The Blackwing on my 99 is made for the larger MAF and it came with a small rubber insert, so that it could fit my MAF....Now that you guys got me thinking I'm going to have to take a look at it tonight, but that's how I recall it was setup.
....so my '98 is 75mm in diameter? I need to check if the one off the '01 Z06 is 85mm. Correct? It shouldn't be hard to find a round rubber adapter to make up that 10mm.(?)
