Air conditioner blower no low setting
Old May 30, 2006 | 05:33 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Air conditioner blower no low setting
A/C works fine, no problem. I have the standard control head, when I set the fan to setting 1 or 2 I get nothing out of it. If I use the higher fan settings it works fine. Any idea what the problem might be? Should I just get another control head, or am I looking in the wrong direction?
Thanks in advance
Bob
Old May 30, 2006 | 06:17 PM
bobc997615's Avatar
bobc997615
blower motor resistor is bad if you have only high fan speed.
Old May 30, 2006 | 07:05 PM
16Again's Avatar
16Again
Settings 1 and 2 are just about nothing. Settings 3, 4, and 5 work fine. Would it still be the resistor?
Old May 30, 2006 | 07:12 PM
rickkym's Avatar
rickkym
You should check the blower control unit, I don't have the resistor values here. I need to replace mine because the blower runs as soon as the battery is connected.
Remove the panel under the glove box and you'll see it right there with about four heavy wires feeding into it.
Old May 30, 2006 | 08:54 PM
16Again's Avatar
16Again
Thanks for the suggestions and getting me on the right path. I'll have a look and see what I come up with.
Old May 31, 2006 | 06:20 AM
bobc997615's Avatar
bobc997615
I believe the blower control unit is that aluminum looking thingy underneath there
Old May 31, 2006 | 08:36 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I had a bad resistor on mine- lost speed 1. The original unit had a printed circuit board with the resistors printed on the board. The replacement unit has actual resistors in the form of coiled wires- like resistors from years ago. Guess they realized the PC stuff wasn't holding up.
Old May 31, 2006 | 09:06 AM
16Again's Avatar
16Again
Is it just a simple swap of the resistor itself?
Old May 31, 2006 | 09:26 AM
bobc997615's Avatar
bobc997615
No, the blower motor resistor is a complete module. No resistors to replace, it's all printed circuit. I bought one for a Sunfire, it cost about $28 from AutoZone (Wells).
Old May 31, 2006 | 10:10 AM
16Again's Avatar
16Again
Thanks for the help guy's. Must be a popular item, just got off the phone with my parts buddy at Chevrolet. They stock the item, very inexpensive, quick plug and play fix. Hopefully i'll pick it up today and all will be well. Thanks again for the direction and diagnosis.
Bob
Old May 31, 2006 | 11:03 AM
DPG's Avatar
DPG
St. Jude Donor '06
yup very common problem with GM. Happened to my friends cavalier and my sisters grandprix. The hardest part for their cars was getting the dash apart. Not such a hug deal with our cars, easy to get to the hvac stuff
Old May 31, 2006 | 02:09 PM
16Again's Avatar
16Again
Man, you just have to love this forum. Great group of helpful people. You were all right on with my problem. I just installed the part and my A/C is now operating perfectly again. Here are pics of the old unit, new UPDATED unit, and where it fit under the glovebox. Thanks again.
Bob
OLD
NEW
Where it goes is the hole in the middle left of photo.
Old May 31, 2006 | 08:31 PM
16Again's Avatar
16Again
Wife can't believe a Corvette repair was only $28.00
Old Jun 1, 2006 | 06:11 PM
MANGOOK's Avatar
MANGOOK
$30 dont forget ther pick up fee . Just playing I am glad it worked. Also I am glad it fit under the seat on the bike.
Old Jun 1, 2006 | 09:07 PM
16Again's Avatar
16Again
Thanks for picking it up for me. You saved your old man a trip.
Dad
Old Jun 1, 2006 | 09:28 PM
MANGOOK's Avatar
MANGOOK
Dad
No problem!!
Old Jun 2, 2006 | 01:03 AM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
Bob
this is why im a subscribing member. this forum has saved me a ton of $$$$$$. the least i could do was pay it forward!!
frank
To Air conditioner blower no low setting
Old Jun 2, 2006 | 01:19 PM
16Again's Avatar
16Again
frank
I pay it forward by doing free repairs for many local members here, as well as giving away extra parts when I have them. This is a great community, you can never know enough and the boys were right on with their diagnosis. My buddy at Chevrolet hooked me up with the new updated part, and my son brought it to me. Nothing like a team repair.
Old Jul 25, 2006 | 10:34 PM
Flyin42's Avatar
Flyin42
THANK YOU!!!! This forum is great! I found my '98 with a dead battery for no apparent reason. When I put the battery charger on, the blower started to run!?! After removing the battery, charging, reinstalling and hooking it up, the blower motor still ran - full, and the switch had no effect. I removed the blower fuse (after disconnecting the battery first) and the blower stopped. After reading this forum, I now know what the problem is!! THANK YOU! $20 part at Advanced Auto
Old Aug 5, 2006 | 01:55 PM
16Again's Avatar
16Again
Going up for ease of Beardown3 to find.
