X-Pipe installation - << welded or clamped? >>
Old Aug 26, 2001 | 10:04 PM
Tiger Shark's Avatar
Tiger Shark
Default X-Pipe installation - << welded or clamped? >>
I know that most X-Pipe manufacturers say you can simply clamp the X-pipe to the pipes where you cut the factory H-pipe out. Is this what you did, or did you weld it? Pros/cons?
I'm asking because I'm having a Bassani X-pipe installed soon and I wanted to get a feel for the way most installers are installing these.
Thanks for the info.
Old Aug 26, 2001 | 10:50 PM
ShanMan14's Avatar
ShanMan14
Cruise-In II Veteran
Cruise-In V Veteran
Default Re: X-Pipe installation - << welded or clamped? >> (targac5)
I just took some pics, sorry for the bad quality. You can see the front is clamped and rear is welded.
Old Aug 26, 2001 | 11:05 PM
Tiger Shark
Default Re: X-Pipe installation - << welded or clamped? >> (ShanMan14)
Thanks for the pics!
What brand X-pipe do you have?
I think the Bassani must be a little longer, because I think it bolts directly to the exhaust system on the rear end.
Old Aug 26, 2001 | 11:31 PM
WHY2KRAG's Avatar
WHY2KRAG
I installed the corsa Indys and I used the corsa X pipe I just cut the one side to fit and bolted the rest on all the way to the rear :smash: Tightened them up a few times as they worked their way through 2000 miles of hard driving. :D Never had a problem :seeya
Old Aug 26, 2001 | 11:40 PM
TooManyIDs's Avatar
TooManyIDs
Welds on each end.
Old Aug 27, 2001 | 01:34 AM
c5magred2's Avatar
c5magred2
Default Re: X-Pipe installation - << welded or clamped? >> (TooManyIDs)
if you dont weld purchase some sort of exhaust leak fix or header wrap and then use the clamps that came with your x-pipe.i know i had problems with a offroad x-pipe and had to remove the clamps and install the leak fix.had corsa indys installed friday and the mechanic noticed the leaks,i already noticed the leaks and was waiting on the corsa install to follow up.mechanic would not touch the leaks ,because the leaks were where the cats use to be. :cheers: :crazy:
Old Aug 27, 2001 | 09:36 AM
Tiger Shark
Default Re: X-Pipe installation - << welded or clamped? >> (c5magred2)
Thanks for the info everyone.
Old Aug 27, 2001 | 12:00 PM
ShanMan14's Avatar
ShanMan14
Cruise-In V Veteran
I bought mine from RG at Exit28 Motorsports.
Old Aug 27, 2001 | 12:42 PM
Tiger Shark
Thanks.
Old Aug 27, 2001 | 01:50 PM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Here is a link to my Bassani X-pipe install.
http://home.att.net/~jansseng/x-Pipe.htm
Old Aug 27, 2001 | 03:48 PM
TorchedTexan's Avatar
TorchedTexan
Default Re: X-Pipe installation - << welded or clamped? >> (Black_Magic)
Bolted..... :jester
Old Aug 27, 2001 | 03:59 PM
MattD's Avatar
MattD
C/R X-pipe - welded.
To X-Pipe installation - << welded or clamped? >>
