resetting oil life % on command center
Old May 31, 2006 | 06:38 PM
idiedtrying's Avatar
idiedtrying
Default resetting oil life % on command center
i changed my oil and dont know how to change my oil life.. it says 9% left.and i need to reset it back to normal...
thanks
Old May 31, 2006 | 06:44 PM
tsts's Avatar
tsts
This is from memory so it could be off a little.
1. Turn key to "ON" position but do not start the engine.
2. Completely depress accelerator pedal to the floor 4 times.
3. Turn key off, then start engine, should be reset now.
Good Luck.
Old May 31, 2006 | 06:52 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Good Luck.
It sounds weird, but that is it.
Old May 31, 2006 | 06:55 PM
shakainc's Avatar
shakainc
I believe you only need to hit the peddle three times. And if I'm not mistaken you can reset it by holding the reset button while your oil life is showing on you DIC.
Old May 31, 2006 | 08:28 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
You are correct.
Old May 31, 2006 | 10:06 PM
rws.1's Avatar
rws.1
Both techniques work
Old Jun 1, 2006 | 07:37 AM
screw991le's Avatar
screw991le
The DIC reset does not work on my car. I have tried it plenty of times. The only way that works for me, is the pedal method.
Old Jun 1, 2006 | 10:23 AM
gorillavet's Avatar
gorillavet
The DIC does work but you must do the following. With the key in the ON position (motor not running) press the reset while in the oil change mode and then TURN KEY OFF. Start engine and display will show 100%
Old Jun 1, 2006 | 05:36 PM
idiedtrying
thanks u guys are awesome!! i would buy a case of beer but i dont know everybody.... =)
Old Jun 1, 2006 | 09:11 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
why would you flood the motor just to reset a monitor????
Old Jun 1, 2006 | 09:53 PM
Z06ufgrad2002
Pushing the accelerator w/o the car running does not introduce any fuel into the engine. These are not carburated engines.
Old Jun 1, 2006 | 11:41 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Old Jun 2, 2006 | 08:31 AM
screw991le's Avatar
screw991le
It DOES NOT work on some cars. I have tried all the ways and the only one is the pedel method
Old Jun 2, 2006 | 01:29 PM
gorillavet's Avatar
gorillavet
[QUOTE=screw991le]It DOES NOT work on some cars.
You are correct, this would only be for 97 to 04 CORVETTES
Old Jun 2, 2006 | 01:54 PM
CorvetteSteve's Avatar
CorvetteSteve
[QUOTE=gorillavet]
Old Jun 2, 2006 | 05:59 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Oh.... I thought the LS6 Intake was a holly! Thanks for your input, it really added something. You still missed my point of my post, but oh well...
Old Jun 3, 2006 | 10:01 PM
fdxpilot's Avatar
fdxpilot
Well, what was the point of your post? If humor, you failed. If serious, pushing the accelerator with the engine off does nothing in the engine compartment on a computer controlled, throttle-by-wire, fuel injected engine. Certainly doesn't flood the engine.
To resetting oil life % on command center
Old Jun 3, 2006 | 10:49 PM
cooluhl's Avatar
cooluhl
That's OK. Fedex delivers to my house!
Old Jun 12, 2006 | 06:50 PM
idiedtrying
LOL.. it worked with the 3 pedals...
thanks again
Old Jun 12, 2006 | 07:01 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
TP for my bung hole? Love the avitar beavis!!!
Dave
O yea the post, just hold reset works for me too
