OK here it is, I don't know how many of you saw my other post with the S4 vs. the modded C5 coupe but in a nut shell, out on the track, I had my top off, did a 70 to 140 pull against a 05 or 06 S4 and was pretty disapointed that I only beat him by a few car lengths. I and others seem to think that the top off is the big difference. SO this weekend I am going to go out on the track, with the top on, run a 70 to 140 mph pull and time it. I will go to the same spot on the track with the top off and do the same 70 to 140 mph run and time it. I want to see the time difference in acceleration. My guess is there will be a 2.3 second difference. The car in question is an 01 M6 with a cam, long tubes, high flow cats, x-pipe, 6" GHL's, underdrive pulleys, smooth coupler, black wing intake, MSD wires and dynoed 375 at the wheels. Lets see what you guys have for guesses. I will keep you all informed!! Thanks, Dan
I would hope we would be much faster than an S4......
Are you sure he just wasn't getting better exit speed out of the turn before the straight???
DH
No unfortanetly I know it was a dead even start. If you look at my other post there are a few that beleive, including me, it has everything to do with the top being off. Even one gentleman has given the difference of coeficient of drag and it has equated into that I would have been an extra 11 car lengths ahead with the top on!! So i want to check that theory by actually timing it!! If this turns out to be the case that will be the last time my top comes off the car!!! Thanks, Dan
I'll bite. I will guess a full three seconds slower.
the all new S4 is 420 hp rated (V8), here in europe...
(just seen a review in a magazine)
Medias here say that's the new s4 can hang porsche and ferraries.
Never seen it on the road for the moment...
as for the top... : less weight but less aerodynamic.
My 2 cents : you're faster with the top
Hey Brice, no change of weight, it was stored in the hatch. Thanks, Dan
Over 200 people look but there is only one guess!?!?!? What's up with that!!! No one is curious, how many of you own coupes?
I had a "on track experience" with a 03 viper(silver color)with his top down. This is when I was at 390rwh. 70 -130 dead even. 130+ started to pull the viper pretty well until 150 when it looked like he shut it down. I always was under the assumption it was due to the fact that the viper top was down. Just a guess
You will do much better with the Top on and I would guess 2.5 seconds. I have read hundreds of threads where a c5 out accelerated a higher horse powered car, because of it design. Take the top off and it is no longer aerodynamic, thereby losing one of its major advantages.
Sorry Guys, I wasn't able to go out and run this weekend, the weather really put a damper on evrything!! The rain up here has been terrible and I can't seem to catch a break, hopefully next weekend!!!
Sure there is areodynamic drag at 100 mph, but appreciable wind resistance doesn't come into play until the race is past half over and 100 mph is just entering the area where it's a consideration. Your under constant acceleration the hp to overcome the difference in air resistance (top up/down) isn't going to materially affect your et. So, my guess is .030 slower with top down.
However your gas mileage with the top down will be awful... lol
