The Alt and Diodes
Old Jun 2, 2006 | 10:25 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Default The Alt and Diodes
My Alt has been acting strange. It takes about a minute after starting the car to move over 13 Volts .I was talking to a guy today and he said he thought it was a bad Diode The Alt has to find another way around the bad Diode and that is why it takes awhile for the Alt to move up to 13 volts. Sounded strange to me but what do I know.
Ron
Old Jun 3, 2006 | 12:49 AM
SFVetteman's Avatar
SFVetteman
I have this problem from time to time. I've tried 3 different alternators and they haven't made a difference. I haven't been able to pin down what the problem is as everything checks out ok.
It might have something to do with the "generator sense circuit', which is the the wire connecting to the S terminal on the alternator. The service manual doesn't have much to say about it except that with the key on and the engine off it should be able to light a test lamp.
Mine doesn't regardless of how the alternator is behaving.
Old Jun 3, 2006 | 11:59 AM
dougbfresh's Avatar
dougbfresh
Ron
Does not work that way, the Diodes convert the AC to DC-there is no "finding another way around it", if one was toast you would no longer have DC but something that looks like AC/DC mixed-half the wave would be straightish the other half rippled. A scope would show this easily. I have not watched mine after startup but I do watch it while driving and it's usually around 14+V When I put the OBD scanner on it it's always over 14-this is more accurate than the voltmeter in the dash. Diodes are easy enough to check, they only conduct in 1 direction. Are you monitoring with the gauge or the DIC?
Old Jun 3, 2006 | 01:31 PM
50th year's Avatar
50th year
Thanks for the info. Didn't make since to me. I am only using the DIC so may it is off. I guess next week Iam off to the dealer. Just don't like that CHARGE SYSTEM FAULT and the Service engine soon light.
Ron
Old Jun 3, 2006 | 02:26 PM
blue98coupe's Avatar
blue98coupe
do you have long tube headers ??? Check you connection at the starter ! If the battery connection is loose there you will show charging system fault .If long tube headers have been installed there is a thin wire that is connected on the large post at the starter solenoid that may be fried .I melted right through this wire after my flp header install .Good luck
To The Alt and Diodes
