New traction control code issue
Old Jun 3, 2006 | 10:10 PM
402Sam's Avatar
402Sam
Default New traction control code issue
Well here is a new scenario. I have been getting traction control code c1278. Now I only get the code when the car is at light throttle. When the car is floored the code does not come on. So whenever I cruise I get the code and the car goes into reduced engine power mode. But if I keep my foot into it the car does not throw the code and pulls like raped ape. I checked the grounds and tried a new battery. Still same thing. A friend of mine had an idea that maybe there is a ground loose and when the motor torques when floored it pulls that ground tight and makes a clean connection. And when the car is not floored and the motor is not torquing over alittle then the ground is loose and is not making a good connection. Anyone got any ideas on where to looks for loose grounds or any other idea on what it could be.
