Some first timer ?s
I have been searching around learning for a while tonight and now I am starting to get confused and possing questions.
I have been seeing people posting.. 01' 3.15 A4 etc.
What is 3.15? Differential? Gears?
And A4 is?
I am a little confused there.
Also if you guys could just answer a few quick basic questions, I didn't get the answers from my searching, probably because everyone knows except me, lol, but bare with me, I am a new owner and I grew up around Mustangs.
I just got a 00' Z51 Vert.
Whats the RWHP rating for my car? At the crank? 1/4 Times?
My cars gears?
I know the engine is much more powerful than my Mustang, any forged internals?
Just curious about things like these.
Also some gas/oil questions.
1. Synthetic Oil only correct?
2. Guy I bought it from said 93 octane only. Now my mustang said 93 only also, but with the gas prices I always put 87 and it was fine. Is 93 absolutely necessary for the Vette, for instance are these cars specifically tuned for 93 octane? Because I know you can tune (with a handheld tuner) a Mustang to use only 93, but I just wanted to make sure the Vette wasn't already stock tuned for 93. Long story short, can I put 87 in my car?
I will have others... Thats it for now.
Thanks a bunch in advance!! Bare with my for now.. Im suck a newbie with Vettes. Never thought I'd own one so soon!
-Mike
Now correct me if I am wrong...
A4 = Auto 4-speed
M6 = Manual 6-speed
Thats what I got from the article and seeing people use the abbreviations.
And I know the car has 345 bhp, but what is the hp to the wheels? The RWHP?
And what about the oil and gas, those questions are important, I need to know that so I don't screw up the car.
Thanks.
A4=4 spd auto trans
rwhp=approx. 293 or so maybe, for stock? (Put it on a dyno, to know for sure.) FWhp=345
1/4=mid to upper 13's, I believe for stock.
1.Don't have to, but it is HIGHLY recommended!
2. ditto
The engine was designed for 93 octane usage. Why veer from manf. recommendations? I can't think of any corvette owner knowingly putting 87 octane in their vehicle. I know I wouldn't.
Having said that, call the dealer for more clarification on 87 octane usage, if you're determined to do it. My guess is, it's pretty much a no-no.
type of oil question
As for gasoline octane, here's what the 2003 Owner's Manual says. I would expect yours reads much the same:
Use premium unleaded gasoline with a posted octane of 91 or higher for best performance. You may also use middle grade or regular unleaded gasoline rated at 87 octane or higher, but your vehicle’s acceleration may be slightly reduced. If the engine octane is less than 87, you may get a heavy knocking noise when you drive. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you might damage your engine.
91-93 Octane is definitely recommended for PEAK performance, but using 87 is not going to hurt the engine.
So thats good news at least for now, thanks a lot for that peice of info, that helps.
https://www.mygmlink.com/
Hope this helps.
He said he brought it to the dealer for the Column Lock Recall a little while back... So he said everything is good to go. So Im pretty happy about that.
