Excessive Rear Tire Wear
Old Jun 4, 2006 | 09:01 PM
gem's Avatar
gem
Cruising
Default Excessive Rear Tire Wear
Mine is a 2001 Convertible with 112,500 miles. I'm on my 3d set of tires. I used Continentals on my 1999 and got great service. My 2d set on this 2001 was also Continenals and I got 55,000 miles out of them. I put a new set on at 96,500 miles. Tonight I found that the rear set is almost bald with only 16,000 miles on them. The front set is fine with lots of tread left. I suspect my shocks (they are original) are gone. What do you say.
Thanks.
Old Jun 4, 2006 | 09:59 PM
rws.1's Avatar
rws.1
post some pictures of the tires and it will be easier to offer opinons...
bad shocks usually result in scalloped wear patterns...
Old Jun 4, 2006 | 10:06 PM
Darkness's Avatar
Darkness
I kinda have an issue with excessive tire wear in the rear, but I dont think its the for the same reason as yours
Old Jun 4, 2006 | 11:20 PM
leojnknsC5's Avatar
leojnknsC5
Old Jun 4, 2006 | 11:26 PM
Sammy_C5's Avatar
Sammy_C5
Old Jun 4, 2006 | 11:29 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
3 sets with over 112K...damn..not bad....I am on set 4 looking at 5 soon with 75K ....but I know what my problem is
Old Jun 5, 2006 | 08:13 AM
vette dan's Avatar
vette dan
Vette Dan
Excessive tire wear on rear is a very bad problem caused by
TOO MUCH RIGHT FOOT !!!!
Old Jun 5, 2006 | 08:56 AM
Billdog350's Avatar
Billdog350
Thanks.
Gem, you have any doubt that your stock shocks are still good after 112,000 mi? I would completely assume that they're junk after that many miles...regardless of how nicely you've driven or how smooth the roads are.
Find some Z06 take off's or buy them new from Fred Beans and you'll be set....I just helped a friend install Z06 shocks in his 1997 Coupe and it really firmed up the ride and reduced wheel hop, body roll, and rattles...though the car still rides nicely. Or you can probably get a set of stock C5 shocks for next to nothing. The job is pretty easy to do as long as you ahve a 22mm socket for the lower bolt.
Old Jun 5, 2006 | 10:06 AM
GUSTO14's Avatar
GUSTO14
Mine is a 2001 Convertible with 112,500 miles. I'm on my 3d set of tires. I used Continentals on my 1999 and got great service. My 2d set on this 2001 was also Continenals and I got 55,000 miles out of them. I put a new set on at 96,500 miles. Tonight I found that the rear set is almost bald with only 16,000 miles on them.... What do you say...
George...
Let me guess, your son/daughter/wife has recently shown an increased interest in driving the Corvette...??
GUSTO
Old Jun 5, 2006 | 02:40 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
When was the last time you had a four wheel alignment?
Old Jun 5, 2006 | 09:19 PM
gem's Avatar
gem
Cruising
Well tomorrow my mechanic puts it on the rack to find out what's going on. Have original shocks and never had a 4 wheel alignment. He'll be checking everyting in the rear. It's not a heavy foot and I'm the only driver. This is my 3d C5. I put 70,000 on a 1997, 80,000 on a 1999 and 112,500 on this one. Never had tires wear as rapidly as this. Even with the crappy run flats, I got over 40,000 miles. A rear tie rod was replaced at 91,000 miles and I wonder if it was installed right. I'll followup with a post as soon as we get an answer.
Thanks for all your suggestions.
Old Jun 5, 2006 | 11:33 PM
saber's Avatar
saber
Tire wear is a problem with these cars - mine even smoke sometimes!
Old Jul 4, 2006 | 07:59 PM
gem's Avatar
gem
Cruising
Well, upon replacing the 2 rear tires, alignment all the rear components were checked. No problems were found. Interestingly, the struts/shocks were in good shape. That led me to contact the manufacturer, Continental. They allowed as how they sometimes have bad tires. The tires are going to be looked at by a local Continental dealer.
Thanks for all the replies. Sorry for all you lead foots who have to cough up the cost of a set of tires in 15K or 20K miles.
Old Jul 4, 2006 | 08:55 PM
99FewteRC5's Avatar
99FewteRC5
Have original shocks and never had a 4 wheel alignment. A rear tie rod was replaced at 91,000 miles
Theres your problem--You had a rear tie rod replaced and never had a 4
wheel alignmet
Old Jul 5, 2006 | 09:11 AM
Black 00 Coup's Avatar
Black 00 Coup
Old Jul 5, 2006 | 09:48 AM
yellow01's Avatar
yellow01
Check
1) Weight of right foot
2) Alignment
3) Shocks
4) Tires (as in quality etc.)
In that order.
To Excessive Rear Tire Wear
