Horn quit working
Old Jun 6, 2006 | 10:37 AM
MY1Fast99C5's Avatar
MY1Fast99C5
Default Horn quit working
So, I woke up this morning and went for a drive only to find out, the one time I wanted to blow my horn, it doesnt work, go figure.
I have checked the fuse,swapped the relay and checked for voltage at the horn (of which there is none) when I press the steering wheel horn button(s). So I am thinking it could be the switch in the horn but I am not sure how to take the sterring wheel cover off. Anyone have any ideas? Or has done this before? TIA
And for the wisecracks out there the horn doesnt blow and neither does the driver
1999 C5 Corvette
Old Jun 6, 2006 | 01:11 PM
JC in XTC5's Avatar
JC in XTC5
1999 C5 Corvette
You're lucky it failed in the off position. Others have had it fail in the ON (stuck) and had to pull the fuse to get it to stop.
Unfortunately, the horn switch is integrated inside the steering wheel airbag area so the entire module needs to be replaced according to those that have had this issue. It's not cheap.
Old Jun 6, 2006 | 01:28 PM
NJ Vette Guy's Avatar
NJ Vette Guy
I wouldn't mess with it, airbags are expensive.....
If it wasn't for state inspection, I wouldn't even fix the damn horn..... I would just yell out the window "Hey azzhole.... Get out of my way!!!"
To Horn quit working
