97-fuel pump location
Old Jun 6, 2006 | 04:54 PM
pawngod's Avatar
pawngod
Default 97-fuel pump location
my car has been hard to start unless its the 2nd or 3rd attempt then if fires right up and runs perfect..i have changed the fuel pressure regulator and that hasnt fixed it..i check fuel pressure and it falls off quickly
thought i would change fuel pump but not sure which tank its in..i assume its the right side cause the left is riveted in and the right has bolts..am i right?? should i replace the pump or just clean the filter screeen....ps..changed fuel filter also thanks
Old Jun 6, 2006 | 06:53 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
If it is just hard to start it is probably NOT the fuel pump. Usually GM pumps just quit all together and don't work again. Also BOTH tanks have a sender and pump.
Old Jun 6, 2006 | 07:00 PM
pawngod's Avatar
pawngod
have any ideas?
Old Jun 6, 2006 | 07:21 PM
RichieRichZ06
St. Jude Donor '08
have any ideas?
It DOES sound like a fuel issue, but tracking it down might suck. One of my techs here said to check fuel pressure first. If you need to replace the pump that supplies the motor it is in the LEFT HAND (driver side) tank. The other tank has more of a siphon pump to equal out the two tanks. Since you tried the filter and regulator I would check pressure and go from there.
Old Jun 6, 2006 | 07:36 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Do you hear the fuel pump run when you turn the key to on position without starting?How old are you spark plugs?
Old Jun 6, 2006 | 08:53 PM
pawngod's Avatar
pawngod
changed fuel regulator...changed fuel filter...still fuel pressure falls off quickly...i have read a post of a fuel feed pipe or fuel feed rear hose part number 10448899 which has a ball valve?? or ? i think its next..under left gas tank..ouch! left side fuel pump is riveted in..how does it come out? seems like they didnt want anyone to remove it?
Old Jun 6, 2006 | 09:01 PM
dpd's Avatar
dpd
97 runs a return line.block off the return side at the rail,if you still loose pressure,most likely you have a bad check valve in the fuel pump.
Old Jun 7, 2006 | 01:17 PM
pawngod's Avatar
pawngod
how do you get the fuel pump out w/rivets?..and full of gas...why didnt they use bolts .ggrrrrr...
To 97-fuel pump location
