LS7 clutch, adjustable master or not??
Old Jun 6, 2006 | 05:56 PM
Phil97SVT's Avatar
Phil97SVT
Default LS7 clutch, adjustable master or not??
For the guys who have gone to an LS7(Z06) clutch, did you use an adjustable master cylinder?
Old Jun 6, 2006 | 07:45 PM
SnowyATX's Avatar
SnowyATX
I upgraded the to the C5 Z06 slave during my install. I did not shim the slave or upgrade the master to adjustable. Whether my setup is optimized or not is a good question. Its definitely holding the power and seems to be almost like stock, maybe a little more force required at the pedal.
Hope this helps....its at least one data point.
Old Jun 6, 2006 | 08:12 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i used the McCleod adj. master w/ a new ls6 slave
Old Jun 6, 2006 | 08:38 PM
78Vette-SA's Avatar
78Vette-SA
Originally Posted by PewterC5
I upgraded the Z06 slave during my install. I did not shim the slave or upgrade the master to adjustable. Whether my setup is optimized or not is a good question. Its definitely holding the power and seems to be almost like stock, maybe a little more force required at the pedal.
I've done a number of LS7 clutches. No shims, LS7 slave, stock MC, no problems. Bleed it good and it works fine.
Old Jun 6, 2006 | 09:31 PM
gsxrjack's Avatar
gsxrjack
exact same with mine, ls7 clutch, new z06 slave..no shim, no adjustable master...clutch works great, I also put the remote bleeder in...best addition i have done.....
Old Jun 6, 2006 | 10:27 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
$350.00 dollars later........
Old Jun 7, 2006 | 01:37 AM
unstressed's Avatar
unstressed
Old Jun 7, 2006 | 07:09 AM
WKMCD's Avatar
WKMCD
I went with the Cartek adjustable master after trying it with the stock one. It raised the engagement to where I like it. Personal preference thing.
But you knew that didn't you.
Phil's done all the major work on my car and done it well.
Old Jun 7, 2006 | 09:56 AM
99blackFRC's Avatar
99blackFRC
No.
Old Jun 7, 2006 | 04:11 PM
M_T_0's Avatar
M_T_0
stock master and slave no problems
To LS7 clutch, adjustable master or not??
