Another PCM code ?
Old Jun 7, 2006 | 12:14 PM
patrickC5's Avatar
patrickC5
Default Another PCM code ?
I recently installed headers w/o cats and picked up some codes. Now I know all my rear O2 codes are from no longer having cats (P0140&P0160). But I also have a P1153 now is that just a faulty sensor 1 bank 2 that just needs to be replaced? I also have a C2120 TPM system malfunction (no sensor recieved), I have no Idea what that is any takers? tThanks guys
Old Jun 7, 2006 | 12:55 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
It could be the sensor, but it could also be an exhaust leak which is causing the sensor to read improperly. FYI, "sensor 1 bank 2" is the forward sensor on the passenger side.
C2120 is telling you that no tire pressure sensors were detected. Did you recently change wheels or tires? Here is a list of codes, including BCM "C" codes.
GL!
Old Jun 7, 2006 | 01:08 PM
SFVetteman's Avatar
SFVetteman
Probably an air leak.
Here's how to re-program your tire sensors: http://www.frankhunt.com/FRANK/corve...g_the_TPS.html
Old Jun 7, 2006 | 02:41 PM
Dustydog's Avatar
Dustydog
Cruise-In VI Veteran
Cruise-In VII Veteran
I was getting the 1153 until I found the leak on the pass side air tube.
Old Jun 7, 2006 | 04:57 PM
patrickC5's Avatar
patrickC5
yes I replaced the tire, wheels, and sensors all new a little over a month ago and programed the tire sensors. coud the tire sensors have been turned off when the battery was disconected while changing out the headers? I will also check for an exhaust leak it is hard to hear it there is one the headers are a little loud!
To Another PCM code ?
