Line lock install, need some help plz!
Got a C5 A4 -98 and a Hurst roll control....
I'm going to make a new brake line from the master cylinder to the distr. block and save the original one for a possible retrofit later on. What dimensions are the connector/fitting in the master cylinder and the distribution block so I can buy the correct nuts? Is the brake line 3/16 or 1/4"? Also, which is the easiest way to get the air out of the system when installed? Bleeding at the distr block or do I need to do it at the wheels?
Thanks!
