C5 light bulb identification assistance needed please
Old Jun 7, 2006 | 11:35 PM
Togo's Avatar
Togo
Default C5 light bulb identification assistance needed please
i found this application guide at sylvania.com
http://www.sylvania.com/ConsumerProd...de/default.htm
and it says the '99 C5 uses a 2057 bulb for the backup light - is this accurate?
has anyone replace all of their bulbs? if so, can someone divulge the quantity of each bulb in this list (if it is accurate) for the rest of us
as i found a site called http://www.autolumination.com that sells replacement LED bulbs that are direct replacements - so NO SOLDERING, NO SEPERATE RESISTORS, NO B.S.
so i'm getting ready to mod the interior with LEDs (if you can call switching out bulbs a mod!)
1999 CHEVROLET Corvette
Low beam headlamp
9006
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High beam headlamp
9005
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
4157NALL
4157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
4157NALL
Rear turn signal
3057
3057LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
3057
Stop light
3057
High mount stop light
%COM
Fog/Driving light
893
893ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
2057
2057LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194
Glove box
194
Map light
212-2
Step/Courtesy light
194
37
Under hood light
561
Instrument-general
194
Automatic transmission indicator
194
________________________________________ ____________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
Old Jun 8, 2006 | 03:31 AM
jdmvette's Avatar
jdmvette
Night Owl for life
yes that # is correct for the reverse lights.
if you need the equivalent LED reverse light it is 1157.
Old Jun 8, 2006 | 08:29 PM
Togo's Avatar
Togo
i thoguht the 2 might have different bases - how can an 1157 LED and a 2057 be the same "input" - isn't the 1157 old school "press and twist" with one contact on the end of a metal "barrel"? and i'm thinking the 2057 is press in with a contact on either side of a plastic end on the bulb.
what i'm trying to do is buy hiperwhite bulbs for my backup lights and my license plate light for that blue glow
i will then be swapping out ALL my bulbs with LED on the inside from
HERE
Old Jun 8, 2006 | 10:45 PM
LoneStarFRC's Avatar
LoneStarFRC
HERE
The 1157 and the 2057 are basically the very same bulb. The 2057 is a newer version. The only difference are the wattages (number of lumens, etc). They are both a round "push and twist" design, with two contacts on the bottom since they are each a dual filament bulb. It's the 1156 and 2056 that are the single contact single filament bulbs.
A 3057 on the other hand is also a dual filament bulb but is of the newer straight press in type design.
HTH,
Robert
Old Jun 8, 2006 | 11:21 PM
jdmvette's Avatar
jdmvette
Night Owl for life
good stuff robert.
the 1157 is the part number i got from the LED site Togo was looking at for the backup bulbs.
Old Jun 8, 2006 | 11:39 PM
Togo's Avatar
Togo
good stuff robert.
guess i'll get those 1157 LEDs then!
seems ODD that a backup light would have more than one contact - i don't think my truck has that - it has 1156
but oh well, guess i can't make that big of a mistake getting the 1157 for trial
thanks
oh, and anyone who feels like trying to put some more quantities on the part numbers on the rest - FEEL FREE
i'd like to replace all of my incandescent bulbs with LEDs inside the car!
Old Jun 9, 2006 | 05:54 PM
LoneStarFRC
thanks
I have seen this a few times on some vehicles over the years. Dual filament incandescent bulbs have one filament that is significantly larger (much higher light output) than the other filament, which is much thinner and smaller. The larger filament of the two is typically used for brake light, turn signal and 4-way emergency purposes only and is normally "off". The smaller one serves as a tail light only and is on when the vehicle's lights are turned on. Without checking a spec book on these bulbs, I would still venture to say that the larger filament of a dual filament bulb puts out far more light than the single filament in a single filament bulb, i.e. 1156 or 2056 for example.
These bulbs and their respective socket designs have been around for many years, and therefore are fairly inexpensive to produce and manufacture. The GM designers in our case spec'd a dual filament bulb and socket, wherein only the larger filament (much brighter) is used. In this case it's for our back-up lights. The smaller filament is not used in this case.
It's just a cost effective way of accomplishing something without "re-inventing the wheel" every time a new model vehicle comes out.
HTH,
Robert
Old May 25, 2016 | 11:03 AM
gpruitt54's Avatar
gpruitt54
I am going to guess that there are LED compatible flasher relays for C5 vettes, so that one doe snot have to install resisters at each LED.
I just did a complete LED swap out on my KIA Sorento and it worked out beautifully. The LED compatible Flasher relay was key in preventing hyperflashing and eliminating the need for resisters on each LED.
Old Sep 1, 2017 | 07:02 PM
RockHeadss's Avatar
RockHeadss
St. Jude Donor '10
This is great info..!! I'm slowly changing to LED bulbs
To C5 light bulb identification assistance needed please
