One of my rear tie rod ends has some play in it, and I ordered a new one from Fred Beans. Can tie rod ends be replaced fairly easily or is it a difficult job and/or are special tools or equipment needed?
havent done one on a C5, but on a C4 is probably similar.
You likely will need a fork to get the tie rod out. My local auto parts store (AutoZone) will loan you one. With that, its pretty easy.
Also should get an alignment after the replacement. I have heard you can get the new one installed close to the same as the previous, and it may be good enough. But an alignment is usually recommended.
Thanks for the help. Actually, I had an alignment done about a week ago and that is how I found out it needs to be replaced. They said after I get the new one installed, they will re-allign that wheel.
I WOULD NOT use a fork because the spindle is aluminum. I just backed the nut off to the top thread and tapped it with a hammer and mine came lose pretty easy. Matter of fact, it seemed too easy. But if it's on real tight, then I would suggest a tool that presses it off. Don't be banging on it too hard with a heavy hammer.
So basically to remove the old tie rod, you remove the top nut, tap it out, and then unscrew it from the inner tie rod? Is that all there is to it? Sounds like a fairly easy job.
Don't forget to count the number of turns it takes to unscrew .... use the same number to install the new one. That'll keep the tires from wearing too badly until you get a re-align
those jam nuts are not easy to break free, sometimes
one more question: I ended up with two new tie rod ends because Rock Auto told me they were out of stock and would cancel the order but they ended up shipping. I had already ordered through Fred Beans, so I now have two. I can return the one to Rock Auto at their expense, but is there any reason to replace both rears even though I was told only the right one has play in it? Or is it better to return one and get my money back?
Since the labor to install is minimal, why not do both at the same time. The alignment after the fact is what's going to cost you...unless you bought a lifetime alignment.
Thanks for the advice, I will just replace both sides now.
